Question about Brother MFC 210C All-In-One InkJet Printer
Print diferent colors
When I need to print in colors, all colors print red.
the black is ok
do you know what I need to do?
I take the red ink deposite and put one empty, now the printer continue to print red but more lightly because the ink red is reduced, and continue more lightly, but only red.
I can to supouse that only la red ink are working
  • 832 Answers
Run a test print by pressing ink etc.
Do you see all 4 block lines (BK/C/Y/M) or just BK and red?
It would be helpfull if you post the test print here!
Posted on Nov 03, 2007
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink printing red
Some printers only use the black ink to provide a darker black. They also use the other colors to print black. That is they use all three to come up with black. If you color cartridge is out of two of the colors, you may be getting just the red. Otherwise you may have a hardware problem.
Jan 29, 2010 | HP PSC 1315 All-In-One InkJet Printer
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Canon i9900 black ink smudging
ok, What cartridges are you using, Are the Canon cartridges?
What paper are you using, is it Canon paper?
If you are to both of these it could be wise ordering a printhead, but this is mostly caused in the uk by None Canon Paper.
Please let me know what you are using?
Sep 24, 2008 | Canon i9900 InkJet Photo Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
The printer colors are not come out right.
Go to this link. Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Apr 29, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Want to print in color ink and not black ink.
These instructions are for Windows Vista users - I've never used XP to do this, but I'm sure it's similar.
Go to Control Panel/Printers and select the printer you want. Click "Select printing preferences" on the toolbar above. The options listed might be different for different printers (I haven't checked) but on my Dell printer I go to Advanced/More Options and under the "Complete-a-Print" section there is a checkbox labeled "Use color cartridge for all black printing." I imagine other printers have something similar. It comes out a dark grey/brown color.
Don't forget to uncheck it when you get more black ink!
Oct 31, 2007 | HP PSC 1610 All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
503 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
