Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL electronics problem
I've some problems with my Maytag Neptune TL. When I switch it on it does not allow me to select all programs. Econo program works fine although when I select Econo LED next to Econo and another program lights up). When I select Normal, then it beeps twice and with Normal pressed twice it changes spin option but do not switch program to Normal. When I click on Spin it also beeps twice and I need to select Spin twice to advance it. When I select Delicate it starts washing (without even pressing the Start button). I've entered the service mode and run Quick Test cycle. It passed. I've run the buttons test and it also passed (although it had the same behaviour as with regular use, Normal button caused double beeps and changed Spin option and so on). I've check the resistance on the connctors between buttons panel and a control board and they seem to be OK except that there is some conductivity between pins 3 and 4 and I don't know if this is OK. Other than that washer works fine. I'm pretty sure the problem is in the electronics but I don't know if I should start with replacing the button panel or the control board. Any suggestions?
Thanks,
Janusz
  • januszkw Jun 20, 2009
    Well, I think I can get the control board for less then $200, still cheaper than good quality washer.
  • januszkw Jun 21, 2009
    Thanks for both answers I received (I have to answer in the comment section as it looks like I cannot post a solution for my own problem). Anyway, the model that I have is FAV6800AWW. The control board I found in a couple of stores for about $180. I don't think I'll be able to get anything under warranty. The washer came together with a house that I bought. I don't have any receipts for it and I'm not sure how old it is. It will be difficult to get replacement from Maytag. Other than that I'm pretty satisfied with this washer as it does quite good job. To replace it I'd need to spend at least $700 for average front load washer so I think I'll take my chances with replacing just the board. The only thing I'm not sure is if the problem is with the board or panel but I guess I'll go with the most common and replace the board.
  • 335 Answers
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
  • dh1200s
    dh1200s Jun 21, 2009
    Ya thru me with the Econo Program . Do you mean Enviro Plus? So you pulled the ribbon cable from the control board and made some key pad resistance measurements?
    I hope that is what you mean with this comment “”I've check the resistance on the connctors between buttons panel and a control board and they seem to be OK except that there is some conductivity between pins 3 and 4 and I don't know if this is OK.””
    You don’t want make any measurements on the control board with the Ohm Meter.
    With the ribbon cable pulled from the control board I checked between pin 3&4 of the ribbon cable with my DVM and read an open. I then made a key measurement (Super Wash) from trace 3&18 on the ribbon cable and measure open no key press, and 96 Ohms with a key press. What did you measure between trace 3&4 in Ohms? Wonder if that is causing this issue….. but you pass the keypad check.
    If you haven’t removed the ribbon cable from the socket on the control board I use this process.
    Squeeze the ribbon cable retainer plug ends to release the retaining clip from the socket which will then slide up the ribbon cable as in this pic. Don't pull on the ribbon cable until you slide the retaining clip up the cable. I would check for any corrosion path issues between the conductive pads on the ribbon cable and the mating socket on the Control Board. Again don’t make any measurements on the socket on the control board. The conductive pads/traces are on the other side of the ribbon cable.
    Let me know if there is anything I can help out with.
    Rich
    Sergeant:
  • 212 Answers
Neptunes are known for the control board, spin bearing and wax motor going bad. replace unit
Posted on Jun 20, 2009
  • kenrick driscoll Jun 21, 2009
    neptunes are good washers. they just take alot of tlc. you get a new board you should get a one year warranty with it but some dealers only offer a 30 day. good luck.
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL
The TL neptune has a small shock absorber on the middle left hand corner behind the front panel. it uses a small wiring clip that could be loose, with a type of inertia switch.
A common issue I've encountered with this machine is underloading. The snubber and springs allow a fair amount of movement. Don't do a few simple items or mixed load in this machine.
If these don't seem to help, let us know.
Nov 04, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl error op
You have lost signaling thru the Left Hand Lid lock or you could have a Lid Magnet out of posistion;
Google Neptune TL Washer FAV6800AWW
6 or so post down and I have service notes to help you troubleshoot.
Mar 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Neptune TL won't spin, continuously beeps through spin settings
if water remains in the tub it will not go into the spin cyc something in the pump clear it and try again
Aug 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
810 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
