Question about Tappan TGF320 Gas Kitchen Range
Digital oven pops breaker as oven starts to light
When I set oven to bake temp and hit my oven pops the breaker. I have tried other appliances in outlet and they are fine.
  • 126 Answers
You have a direct short. A wire or component has touched ground .Gas or electric?electric check connections at bake and broil elements in back.Gas look for broken wire /connection at ignitor or ERC ,(control board)
Posted on Jun 20, 2009
My fridgedaire oven will heat up fine on broil but when I put it on bake it only gets to 280 and stops heating
Good Afternoon Friend,
I understand your Frigidaire range, model# PLEF398AC, heats up fine on broil, but only hits about 280 degrees F when put on bake. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and try setting the temperature to 350 degrees on bake. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLEF398AC Electric Kitchen...
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
I hit bake & it says off. I can't get the oven 2 say anything but off. Usually I hit "bake" & then up arrow 2 set temp but now as soon as I hit 'bake' or anything else it says '
Power reset it from the circuit breaker and if this does not help the control panel become more adverse to your selecting, then contact a professional. Sounds like the control board is going out.
Dec 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Tappan TGF320 Gas Kitchen Range Logo
76 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
