Question about Philips Zenia Voice Cordless Phone
Need a factory reset on Philips Zenia Voice 6626 handsets.
I have several Philips Zenia 6626 units, all working fine. Two I bought used and they are trying to register to some base unit which I don't have (and different to each other too). I think they require a factory reset but the menu does not seem to have this. There are contacts inside the battery cover but poking about with these is likely to damage something.
I'm looking for a reset to factory condition, to try again, before I conclude that both handsets are defective.
3 Suggested Answers
SOURCE: How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Posted on Mar 12, 2009
najah
  • 180 Answers
SOURCE: PHILIPS Zenia 200 6626, handset has stopped charging
Replace the batteries.
Posted on May 24, 2009
Hi, I have a philips cd235 cordless phone. The answer machine flashes CL and I cant get it to stop. Ive taken all the batteries out and turned off all the phone over night and reset handbase. Can anyone...
Hi,The voice time/day stamp on the answer system needs to be set, this is true even if you have Caller ID. The day of the week will still need to be set manually.
Thanks and take care
May 22, 2010 | Philips Zenia Voice Cordless Phone
Trouble is it fell in to some (water handset only) Dried out over 2 months but then battery wouldn't charge properly. Bought new battery and it charges but does not stay charged and then everything on...
sounds as its still damp inside of handset. u could strip down and make sure the water hasnt coroided any contacts which is making it discharge to earth.
with regurds replacement handsets , i have been looking for spare base as mine is just started going and cuts calls off ( sound like dry joint in base unit or power supply is giving up) try a philps dealer to see what spares philps have other than that it secound hand units.
Jan 23, 2010 | Philips Zenia 300 TU7370 Cordless Phone
Bonjour, je n'arrive pas à associer ma
Il faut utiliser le code RC qui est marque sur l'etiquette au dos du repondeur !
Oct 06, 2009 | Philips Zenia Voice Cordless Phone
I have lost the instruction manual - is there an online version?
Hi
here is a downloadable version of the instruction manual...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=CORDLESS_PHONES_CA&sct=DECT_PHONES_SU&grp=PHONES_GR&session=20090426060330_93.97.209.201&ctn=TD6626/BB051P&mid=Link_UserManuals&hlt=Link_UserManuals
Regarding using the base on its own, I cannot see why not if you have all the working buttons to control functions you need on it.
If you are going to use other phones with this please take into account REN values on your line. Most lines will support upto and including 4 REN value. Nearly all phones will have a REN value of 1. So ideally only have a maximum of 4 phones (may get away with 5 if you are near an exchange?)
Hope that helps?
Apr 26, 2009 | Philips Zenia Voice Cordless Phone
Call waiting Phillips Zenia Voice 200 Digital
Hi
Even though you phone supports call waiting, I think you will find you will need to have the service enabled on your line by your service provider. If you have already done this have you tried a different phone with 'R' button (used to access extra services). Another thing to try if service is on your line is to check on base of phone to see what setting the TBR (timed break recall) switch is set to and try switching to opposite to see if it makes difference? This controls how the phone reacts to commands using the R button by way of sending tones down your line.(I know if your in UK it should be set to TBR). Hope that helps?
Mar 06, 2009 | Philips Zenia Voice Cordless Phone
Standard RC Code
Try to type 0000 (four zeroes!)
Aug 27, 2008 | Philips Zenia Voice Cordless Phone
Philps Zenia 200 Cordless Phone -- Voice mail problem
It might be worth resetting the software for teh phone. Not sure if it is the correct solution, but it might be worth a go. To complete this process, please implement the following: 1) Disconnect the power cable from the main base station. 2) Remove the batteries from all of the handsets. 3) Leave for 5 minutes and then connect everything back again. Please note that this process will not delete any telephone numbers from your phone book or any other saved information. If applicable, you will need to set the time and date.
Jan 22, 2007 | Philips Zenia 300 TU7370 Cordless Phone
Philips Zenia Voice Cordless Phone Logo
628 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
