Question about Mitsubishi VS-60601 60" Rear Projection Television
Mitsubishi VS60601 Any know how to/where to order replacement lamps for my Mitsubishi VS-60601? I've had this 60" model tv since 1998. It has been amazing. However, after over 10 yrs of service, it now needs replacement lamps. With a relative "dinosaur" of a television, it has been difficult to find these. Thanks!!! -Sean / skgradney@hotmail.com
  • 1 more comment
  • skgradney Jun 27, 2009
    I really prefer to find the lamps, no matter the costs. I LOVE this television and want to keep it for another 3-5 years.
    Would Mitsubishi not sell replacement lamps for older models like mine?? It's a 1998 design.
    Any one how to/where to order replacement lamps for my Mitsubishi VS-60601?
    I've had this 60" model tv since 1998. It has been amazing. However, after over 10 yrs of service, it now needs replacement lamps. With a relative "dinosaur" of a television, it has been difficult to find these. No local shops seem to have them either.
    I'm willing to pay, money is not an issue.
    Thanks!
  • skgradney Jun 29, 2009
    Thanks!
    President:
  • 1,314 Answers
I have looked through my normal TV parts stores and have been unable to locate one.
However, do you have a part number of the bulb? It is possible it can be cross referenced. Pull the bad one in question and see if there are any numbers on it and post back here to let me know. Please do not rate this solution until we are done or I will be unable to help you further. Thank you.
Posted on Jun 29, 2009
  • 952 Answers
Hi sir, finding a spare lamp for that TV is like hitting the jackpot.. try to call express repair center @ 1-877-260-9965. ask for the VS6061 lamp. if they don't have it in stock anymore, you'll probably have a better chance if you'll just search for a defective vs6061 and just salvage it for spare parts... sorry sir, but your tv probably broke down because its probably a sign for you to get a new 50" LCD tv =) cheers
Posted on Jun 27, 2009
  • 10,594 Answers
Its an old model TV and I'm afraid Lamps ( 3 CRTs red-green-blue) are not available in any parts-shop.
I would recommend to buy new TV instead of spending money on its 3 lamps, if available.
Thanks.
Posted on Jun 20, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jun 27, 2009
    Get back to you shortly, let me search lamps for this TV some where available or not.
    I'm afraid, no lamp is available any where for this TV VS-60601
    Please check with local TV repair shops as they might have any similar model dead TV inside to get its lamps.
    Mitsubishi provide parts up to 5 years of model launched.
    Thanks.
    Money can't buy thing that does not exist any more. Sorry.
The outer screen of my tv is cracked and i was trying to find out where i could order a replacement
Idealy if you contact Mitsubishi online they can issue a list of service centres that can supply a new screen. Otherwise, have a look at ebay, you may find a supplier there.
You will need to order the correct screen as it may be made up of two parts, an outer screen and an inner optical screen, depending on its production age.
Hope that helps.
Nov 23, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 60 in.
I just encountered the same problem. What was your solution?
Sep 12, 2008 | Mitsubishi VS-60601 60" Rear Projection...
VS60601 Picture yesterday, none today
That model will usually leak coolant directly onto the vertical output area and that will put the tubes into protective blanking and you will have sound but no picture.
Aug 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
May 04, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
VS-60601 Mitsubishi Problem...
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Oct 24, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
