Question about Dayton (4LX41) Heater
My pilot light and it run for about 5 mins and shotoff
My heat will not stay on
  • vshead Dec 10, 2007
    pilot light works for a day or 2,after putting on new thermocouple
  • 625 Answers
Does your use a spark to start or a hot surface ignitor?
Posted on Nov 04, 2007
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
How to relight pilot on boiler
Every boiler will have manufacturer lighting instructions on the unit, so be sure to read it thoroughly and turn off the gas for 5 min to make sure there is no gas build-up around the boiler. Some have electronic ignition and some require a manual lighting of the pilot. If the control knob has only ON-OFF, it has electronic ignition. Simply turn off the power (at the electric switch on the boiler or at the breaker box) and then turn it back on and it will relight itself when heat is needed) If it has ON-OFF-PILOT, you will have to light it manually. You will have to turn the gas valve knob so the arrow is pointing at the word "pilot" and depress the knob, while lighting the pilot with a lighter or match. Continue to hold the knob down after the pilot is lit for about 30-45 seconds to allow the thermocouple to heat up. If you release the pilot knob and the pilot stays lit, you can turn the knob to the "ON" position and the burner will light. Please be careful. if you are not sure what you are doing, call a professional.
Mar 01, 2015 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
My mr heater wont stay light unless its above 3. It only stays on about 5 min then pilot goes out. It is gas heater. What's wrong with my heater?
Theres a thermostat inside, if its too cold and not warming up the thermostat enough it will shut off because it thinks there is a problem.
Feb 07, 2013 | Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
With out brand and model # all i can do is to tell you to check heat exchanger for holes or flame roll out, Check limit switches if not then could be gas valve
Dec 20, 2010 | Heating & Cooling
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
Dayton (4LX41) Heater Logo
35 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
