Question about E-Machines etower 667ir PC Desktop
I have an old e machine Tower Mod.667IR S/N QA309-108-O2995 no manual on hand. Please advise correct drawer ID. Top drawer C or D ? Mid drawer C or D ? Which drawer is the Burn drawer? Bottom drawer is for 3 1/2 floppy. Kindly advise how to copy data from floppy to CD R or CD RW ? Which is best choice? I am using MS 2000 Pro. and have Nero burn prog. Thank you very much Wally
  • 97 Answers
Your master hard drive will be C, slave hard drive or top media drive will be D, and so on unless you have reconfigured them from the factory setup. Floppy disks only have 1.44 megabytes on them, so easiest way to copy data from them is just to drag and drop all the files into a folder on your desktop. Insert a blank CD-R into your writeable drive...win 2000 will open a blank cd window. drag and drop the files you wish to copy into the blank cd window and click "burn these files to disc". A CD-R has 700 megabytes on it, so roughly 675 floppy discs can be copied to a single CD-R.
Posted on Jun 20, 2009
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
I need an operational manual for canon smartbase MP360
You can get the user manual for this printer from this link, just click HERE and proceed with the download.
Nov 25, 2010 | Computers & Internet
E-Machine power supplies
search in this page
http://www.cputopia.com/emachine-480w-d-series-d3415.html
May 20, 2010 | E-Machines eMachines Desktop PC
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need manual or instructions for connecting frint
The model of the motherboard is actually more helpful. Most of the FP Connectors will be labeled, i.e. HDLED +/-, PWR LED +/-, etc. Loook in your motherboard manual for which pins they relate to.
Dec 24, 2009 | Power Up 2532 Silver ATX Mid-Tower Case...
I need my emachine 667ir to run at 32bit the highest it will go is 24im broke i need a free fix
ten year old computer, never going to upgrade past 256 memory. not enough to run Windows XP properly. Not going to happen sorry.
Nov 28, 2009 | E-Machines etower 667ir PC Desktop
Where to put the detergent and liquod softener in newHaier washer
Detergent goes in the drum with the clothing, fabric softener in the middle of the agitator, the drawer is for delayed start if using soap powder
Apr 04, 2017 | Haier XQJ50-31 Top Load Washer
My Zanussi ZWF1430W won't take fabric conditioner from drawer - it washes and spins okay on all programmes.
Sometimes the drawer gets blocked with congealed fabric conditioner and or old soap powder, try removing the drawer and giving it a good wash. An old toothbrush is useful to get in the small areas. To remove the drawer: Pull the drawer out as far as possible, there is a small depression on the left hand side at the top of the drawer, about the size of a fingertip press the depression to release the drawer, and pull the drawer out. To relocate, line the drawer up, and place the long thin piece of plastic on the left hand side in the corresponding slot in the top of the drawer opening, you might have to kneel down to see it and slide the drawer in, you might have to press the depression again to pushe it home.
May 04, 2009 | Zanussi ZWF1430W Front Load Washer
Soap dispenser drawer jammed
I would not say that is normal wear and tear, but the fabric softener or bleach dispenser may not have gotten replaced correctly after they were removed. You should rarely have to clean these out (as they are flushed with water on each cycle) Make sure they are installed correctly and you should not have repeat problems. Now, Here's a possible solution to the current jammed dispenser: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Feb 06, 2009 | LG WM-2077C Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
E-Machines etower 667ir PC Desktop Logo
114 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
