SOURCE: vga driver mb asrock 775vm800..
Here iss the link to the Asrock download you requested:
http://www.asrock.com/mb/download.asp?Model=775VM800
SOURCE: Problems with Asrock 775VM800 Motherboard?
try to download and install drivers for VIA USB CONTROLLERS from www.asrock.com
SOURCE: im using asrock 775vm800.have no sound...i already
To get sound you need to install the driver for it. Get it from here
http://www.asrock.com/MB/download.asp?Model=775VM800
SOURCE: my asrock 775vm800 restart automaticlly
Plz check the CPU temperature in BIOS>>Hardware Monitor if it is >70 it the problem with your CPU heatsink fan fixation problem. You need to clean the processor die and heatsink contact with IPA (isopropyl alcohol) and apply small amount of heatsink cement in heatsink fan and reinsert heat sink. Make sure all the heatsink fixing studs inserted in motherboard properly, it can be inspected by the bottom side of the motherboard
SOURCE: what is the maximum size
I think the actual size of hard drive is unlimited, certainly Asrock make no claims that there is a maximum size. I would however, to be on the safe side, install only a 1TB drive. You could of course get a larger drive and partition it into smaller partitions, which should bypass any possible size restrictions
