Wife power up machine...blinked and shut down...
1) no power to display, power on/off does not work, ...unplugged
2) went thru no power from 8-2 in LG Repair Manual (p 23)
Ordered Filter Assembly, PWB, and Display PWB just to cover basis.
Have installed all new and still cannot get LED on PWB "on". I am getting 120+ or so volts to Main PWB, however, LED is not on.
Looking into ball sensor and pressure switch.....loosing patience
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
I HAVE A BEKO 42WLH530HID TV, AND WHEN I TURN IT ON THE STANDBY LIGHT COMES ON BUT NO PICTURE OR SOUND, I KNOW ITS 1, OFF 3 CIRCUT BOARDS BUT DON,T KNOW WHICH ONE, CAN ANYONE HELP ?
Hello &
Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall effect sensor is used in these washer which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when
their is an issue with the motor or when the hall effect sensor sends wrong
signal to the control. Conclusion is you'll have to check both motor and hall
sesor and replace the part# that is bad, usually I have seen the sensor going
bad. Please get back to me if you have any other questions.
Kevin
