After a longtime in storage i connected my adcom gfa power amp to a adcom gtp-350 tuner/ pre-amp to a klipch ksw sub woofer and a pair of small energy speakers. i realized the left channel was alot weaker than the right channel while listinig to an fm station on line. i wiggled the speaker wires on the back of the sub woofer to see if there wasa loose connection. i heared a pot sound and what seemed like a spark and then nothing. i've looked at the fuses on all three components and they look fine. when i turn everything on all i hear is a faint bass note sound at a fairamount of gain level. what should i do now?
  • raymondpaint Jun 20, 2009
    i have a pair of book shelf speakers, but would't that be the same as disconnecting my left and right channel speakers from the sub woofoer and connecting them directly to the power amp?
    if i elliniate the subwoofer and the system works, what could happen after allowing it to run more than a minute?
  • 2,071 Answers
One of the common trouble of electronics unit longtime is not use is a cold solder in power amplifier section.A cold solder joint is where a lead of a component is not soldered at a high enough temperature and results in a bad electrical connection which can respond to physical shock and thermal stress. A solder joint may also be broken or cracked because the receiver was dropped or hit.When you open the receiver look on the front and back of the board along the defective circuit to see any components that look like they are not soldered effectively or the solder connection is cracked or broken. A cold solder joint looks dull and/or bulging unlike the smooth and shiny normal solder joints.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing..If you're not experienced with troubleshooting and repairing electronics, I strongly suggest look for professional service.
Good luck..
Regards:
VOTIT
Posted on Jun 20, 2009
  • LORETO LACARON
    LORETO LACARON Jun 29, 2009
    Even you elliminate the subwoofer and allowing to run for a longer time or an hour there is nothings happen. Its much better you reworks the solder parts joints so it will works better performance.
    Regards:
  • 3,230 Answers
Well, it seems like that there must be some short circuit on the pre-amp., now u can try pluging a external speaker with a adapter, if this external speaker works that means there must be some loose wire(connection). check this.
Good Luck!!
Thanks
  • Mukesh Kumar Jun 20, 2009
    Yes, you can try connecting tham but do not try this for more than 1 minute.
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
I have a Adcom GTP=600PreAMP.Will this unit run a Gfa=5500 and a Gfa=535 Amp at the same time? I need to power Peavey 15's and 12's,and Peavey Horns, which are all each in there own Cabinets? HELP?
Should not be a problem, just bridge them together from the Pre out.
It´s all a question of impedance matching, but just 2 amps in parallel is no sweat. Then adjust volumes on the Amps.
BE CAREFUL THOSE HORNS HAVE CROSSOVERS, THOUGH !
Low frequencies will FRY THEM !!!
Be good.
Jun 07, 2015 | Audio Players & Recorders
I want to bridge 2 adcom GFA 555 amps to my sony DA7ES any suggestions
Obviously you are going to use the Front pre-out's on the Sony to drive the Adcoms. its pretty straightforward, just do not use a speaker that is less than 8 ohms. and make sure that you always have the power switch off on the adcoms, let them sit off for 5 minutes, THEN hit the bridge switch on the back of the adcom's and follow their instructions for bridging. it's pretty easy and tough to go wrong. Good luck...Rob
Apr 18, 2015 | Adcom GFA555 Amplifier
Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
Can you bridge an adcom GFA-5802 power amp?
Running an amp in bridge mode requires a specific circuit design. It is not possible to combine 2 amps in this fashion.
Dan
Mar 02, 2009 | Adcom GFA-5802 2-Channel Amplifier
Just buy an amp
Yes, -- the GFA555ll is a power amp that needs a pre-amp for control. A good recommendation would be GTP500 pre-amp
May 29, 2008 | Audio Players & Recorders
I need help with a system that I just bought.
Well it should be like this...Your amp is prologic which means that it has 5+1 outputs (sub out may be for active sub).Connect your speakers on specific output for each one (center,front left,front right,rear left,rear right and sub).Other devices,CD,tuner...connect to the amp with signal RCA-RCA cabels.On the back of the amp you have all marked inputs.You wasn't specific what do you want to hook?!If you want to hook this "new" to kenwood connect rec out of it to aux in on kenwood.If oposite kenwood rec out to "new" aux in.Hope that this is what you need
Mar 12, 2008 | Audio Players & Recorders
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
71 people viewed this question
 Grubhead
Grubhead
