Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Model GHW9100LW1 door latch is not working
    Sergeant:
  • 212 Answers
Replace latch
Posted on Jun 20, 2009
Age of Whirlpool Duet Serial Number CSP 2807389?
Age of whirlpool duet washer/dryer with sn csr2213663 model either ghw9250mt2 or gew9200lt1
Jan 31, 2014 | Whirlpool Washing Machines
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet ghw9100lw1... the washer will not finish the spin cycle of the load and now will not unlock even though it is off and all canceled out first- how do i open the door to get the heavy...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to change Whirlpool Duet front-load washer (model: GHW9100LW1) rubber seal (the bit gray rubber ring that's between the front door and the drum)?
If you are referring to the door bellow, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you haven't purchased a replacement yet, you can find one at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer door wont latch ghw9200lw duet
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool -ghw9100lw1 wont start sicle
defective timmer, defective water level pressure switch open circuit
Oct 08, 2008 | Washing Machines
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9100lw1
Try holding the End of Cycle Signal button for about 3 seconds and see what happens. Mine started working again.
Ok Yankee
Nov 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
189 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
