Question about Kodak EasyShare V610 Digital Camera
Lens needs to be manually opened
More of an annoyance than anything. My Kodak V610 lens won't open when camera is turned on. I then open the lens and turn the camera on.
I just repaired this problem on my daughter's camera today! I took out the 4 tiny screws that hold the front cover on and discovered gunk and goo that were keeping the lens from retracting. Please note the exact position of the screws. They are different sizes. I then very carefully cleaned all the residue using Q-tips dipped in rubbing alcohol. It worked perfectly! Just like new.
Posted on Jul 04, 2009
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Kodak V610 will not turn on. I have bought a new battery KLIC-7001 3.7V the camera charges has charged the battery but the camera will not turn on.
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Oct 26, 2011 | Kodak EasyShare V610 Digital Camera
Kodak v610 camera (easy share) My 10 year son was using our v610 camera and the following error message E45 (please see user manual) appeared on the screen. We were unable to switch the camera off and...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Jan 15, 2011 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 "Camera Error
Hello
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Dec 13, 2010 | Kodak EasyShare V610 Digital Camera
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
Errer #45 kodak v610
The problem seems to be with your lens guide it is out of track so please follow the step below,
Try forcing the camera lens but be careful while doing this if something goes wrong your camera our lens can be damage
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
If no luck then contact your Kodak service centre
Thank You
Oct 01, 2010 | Kodak EasyShare V610 Digital Camera
Camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
My camera error # e 45
This is a lens fault and unfortunantly the cam. needs a repair.
In order to arrange the repair: Pls. contact your dealer or KODAK directly:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=4248
Sep 27, 2009 | Kodak EasyShare V610 Digital Camera
Turned off camera, opened hatch to battery and memory card too quickly. Turned on camera Error E45 displayed on screen.
Hello
Regards
Andrea
Apr 18, 2009 | Kodak EasyShare V610 Digital Camera
Kodak V610, Lower lens not working
I had the same problem. The lower lens wasnt working, but if i zoomed enough the screen would turn back on.. Heres what worked for me.. go into menu, select setup menu, then select digital zoom. and select "off" . now the botton lens should work. take a picture, and then go back into digital zoom menu and select on, and all the zoom views should work!
Oct 07, 2008 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
275 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
