Question about Toshiba 57H82 57" Rear Projection Television
THE PICTURE IS WAVEY...THE CIRCUIT BOARD NEEDS TO BE REBUILT
  • Toshiba Master
  • 3,459 Answers
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directionsTHE PICTURE IS WAVEY...THE CIRCUIT BOARD NEEDS TO - 0667c5f.pngrgence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 21, 2009
Why is my color distorted on my 60737 hd tv???????
Try resetting the tv By pressing the power button on the set for 8 seconds if that doesn't work try unplugging your video source (cable box, sat box, ect) for 20 sec then plug in. if all those don't work then service is needed. the formatter board needs replacement.
Feb 21, 2015 | Mitsubishi WD-60737 60 in. HDTV
42" Sony flat screen picture distorted wavey.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 16, 2014 | Televison & Video
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Long warm up time
you have a bad capacitor in the deflection circuit.You will need some diagnosing and testing to find which one. An ESR meter will make short work of that but they are expensive meters.
Mar 22, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Tv repair?
The waviness is most likely a weak capacitor or leaky diode in the deflection circuit. The logo is burned into the tubes phosphorus from being left on the espn station all the time. That would require new tubes or have yours rebuilt either way that will be expensive. Repair the waviness should not be that expensive I would estimate a shop charges tobe between 150 and 300 depending on where you have the repairs done. Hope this helps.
Jan 26, 2008 | Samsung HCN653W 65" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
193 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
