Question about Dell Dimension 2400 PC Desktop
Error after memory upgrade
I upgrade a dell dimension 2400 from 256mb to 1gb of ram turned on the computer and recieved three beeps and an error code of green ABC yellow D.
  • JDTec
    JDTec May 11, 2010
    Verify that it is the correct memory type.
    DDR 266MHz PC2100
    Or
    DDR 333MHz PC2700
    Problem Solver:
  • 6 Answers
The frequency of 256mb ram is nt equivalent to one gb ram
Posted on Jun 20, 2009
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Would this particular RAM work with my Dell Dimension 2400? http://cgi.ebay.com/KINGSTON-1GB-DDR-PC2700-ECC-REG-KVR333X72RC25-1G-RAM-/380226148054?pt=LH_DefaultDomain_0&hash=item58873e96d6
According to the Dell specification found here:
http://support.euro.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm#1105481
your PC does not support registered ECC RAM.
Most desktop PCs use unbuffered RAM. Registered ECC (Error Checking and Correcting) is a special type of RAM mostly used in servers.
Unbuffered RAM is faster than ECC RAM and is usually cheaper.
To find RAM that is compatible with your PC try the memory configuration tool at www.crucial.com
Please rate my answer is this was helpful.
Many thanks,
Chris
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I want to add more ram. Where do I get it? Dell
I hate to be the bearer of bad news, so don't 'Shoot the Messenger'!
The Dell Dimension 8200 Desktop PC uses RDRAM ram memory.
VERY expensive stuff!
Supporting Data:
This is Dell Support, Manuals, and the Dimension 8200 Service Manual,
http://support.dell.com/support/edocs/systems/dim8200/
Scroll down the list to the heading - Specifications, and left-click on it.
Scroll the page down until you come to the heading - Memory
Now look at the first subheading - Architecture
RDRAM
You have 4 ram memory slots. (memory connectors)
EACH, ram memory slot can support up to a Maximum amount, of 512MB. (512 MegaBytes)
TOTAL Maximum Amount for your computer is 2GB. (Not shouting)
1024MB = 1GB. (1024 MegaBytes = 1 GigaByte)
The type of Rdram ram memory is PC800, and it is Non-ECC.
(Error Correcting Control, or also stated as Error Correcting Code.
Used mostly for Server computers. Your computer does not use ECC ram memory)
In My Humble Opinion, (And again, don't shoot the messenger), it would be better money spent to buy a decent affordable computer, than it would be to upgrade the ram memory in this computer.
This statement is based upon the fact that the Dell Dimension 8200 ships with 128MB's of ram memory.
(Makes it a pretty slow computer. Rdram or not)
The average cost to install, for example, 1GB of ram memory is OUTLANDISH! (Not shouting)
Example 1:
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=24927
Example 2:
http://www.pcmemorystore.com/Dell-Dimension-8200-ram.htm
For about another $100 you can buy a pretty decent new desktop computer, that will run the one you have in circles.
Just my thoughts.
Dec 07, 2009 | Dell Dimension 8200 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
PC beep 5-2-2-1 code on startup, no posting
I THINK IT IS MEMORY UPGRADE, ALSO MAYBE A PARITY ERROR, SOME MEMORY DO NOT NEED PARITY ON THE CHIP SET, AND IF IT HAS PARITY ON THE CHIP THAN YOU GET ERRORS,
REMOVE THE NEW MEMORY AND SEE IF THE MACHINE WILL WORK IF SO THAN THERE IS SOMETHING WRONG WITH THE NEW MEMORY,
RAM TYPE: EDO, PARITY AND NON PARITY MEMORY, FPM MEMORY, THE CACHING MEMORY NEEDTO TO HAVE L1 OR L2 OR EVEN L3 CACHING CAPABILITIES,NMI ERRORS .
not:::: EAch manifacture may have a different voltage in the curcuitry and it may have the wrong voltage but i think that way out there and not to even consider it.....
does the manufact even allow that much ram upgrade???
rod
Feb 03, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400 PC Desktop Logo
176 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
