Question about Garmin eTrex Vista HCx Handheld GPS Receiver
Compass in 3 parts on the screen
When navigating a route, part of the 'shaft' of the compass arrow is detached and off to one side from where it should be. It is sometimes green when the rest is red. It points in the same direction as the arrow head. The arrow indicates a direction up to 90 degrees out from the correct direction (45 deg. east or west). It's been calibrated several times without success. It has worked correctly before.
This is normal! The compass looks like this in "course pointer" mode.
When you're looking at the described compass screen, press the lower left button and notice the line "bearing pointer". When you select that line and push the front joystick, you'll notice that the compass needle is "normal" again . And when you push the lower left button again, you'll see that the line has changed into "course pointer". Pushing the joystick again toggles between those two modes. The shifted needle indicates how far you drifted from the course that your route follows. See page 31 of the English manual for details.
Jean-Marc Bouyeure
Posted on Jun 27, 2009
2009 fusion SEL has data compass error after being rear ended and a shop did repair.
WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION ...
www.fixya.com/cars/t16705785-compass_error_2009_ford_fusion
Feb 21, 2013 - WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION A MESSAGE COMES UP ON MY DASH SAYS COMPASS NO ... SOURCE: I HAVE A2009 FORD FUSION AND IT'S NOT GOING OVER 20 MPH ... Compass data error -- how do i determine my zone-- ... Jan 28, 2010 ' 2007 Ford Edge SEL Plus.
Compass - Ford Fusion Sport - Ford Fusion Forum
www.fordfusionforum.com/topic/9390-compass/
Jan 23, 2013 - Compass - posted in Ford Fusion Sport: 2011 Fusion SEL without navigation screen. Following windshield ... I have recalibrated and reset the compassaccording to the manual instructions (several times) but cannot correct the error. Can anyone help? ... picture of where it is: 2009-08-30_051718_2.gif.
Nov 08, 2015 | 2009 Ford Fusion
Why would I need a compass on my camping trip?
A compass is advised when you're going on a hiking trip in an unfamiliar environment where you have to use some navigational skills; the compass is very useful in helping you navigate to the right direction.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
My compass doesn't point north, what is the reason?
The reason why your compass doesn't point to the north anymore is because the compass has been exposed to articles with iron content, like the compass being placed next to a pair of scissors or a knife, microwaves, and high tension wires.
Sep 03, 2012 | Acr Electronics Camping, Backpacking &...
Can I check for errors in my compass myself?
Yes, you can check for error in your compass by aligning the vessel on known headings. The Compass Adjuster Pelorus allows for all the headings to be easily checked.
When is a compass in need of repair?
    • 1.
      When there are cracks in the dome.
      2. When fluid levels are low,
      creating a bubble or fluid is all together empty.
      3. The dial or card is
      discolored or yellow.
      4. When the dial begins to stick
      * follow these steps to test dial.........
      While dockside take note of the compass heading. Hold any magnetic object
      to the compass so that the original heading is deflected about 10degrees.
      Remove that object, and see if the dial returns to it's original
      heading.
      Repeat this several times deflecting the compass to both sides.
AdChoices
Jul 09, 2012 | Camping, Backpacking & Hiking
Sat nav on jag xf. the direction arrow on sat nav always points in compass direction of travel ie if going south then arrow points down over. is it possible to have arrow always pointing up like tom tom
the touch screen on the car should allow you to change the compass setting...I cant remmeber if yours has this but see if you can touch the compass on the screen display to make the direction allow of the car be in accordance with the cars real movement or north as you wish..Keep me posted
Sep 12, 2011 | 2010 Jaguar XF
I have never used a dive compass before. Is there a manual as I bought it on ebay?
There is no manuals for scuba compass, I dont know what scuba school you hold your open water cert with but all scuba organisations such as PADI, SSI etc etc will cover navigation as part of there basic and advanced scuba education.
Sep 22, 2010 | Oceanic Clip Mount Maxtilt Compass -...
2001 Toyota Prado (exported from Japan). Compass reset procedure.
Hi, don't know if you figured it out, but I just (literally 10 minutes ago) calibrated the compass on my 2001 LandCruiser Prado by doing the following:
- Press the up and down arrows together until the inclinometer starts to blink.
- Then press the "Mode" button to switch to compass. The compass should start to blink.
- Drive your car in a 360 degree circle until the compass stops blinking.
- And that's about it.
Even though this is an old question I wanted to post the answer because I've been looking at this issue for a year and haven't found the solution online.
Please note that this page http://www.tlocuk.co.uk/forums/viewtopic.php?p=2302&sid=327bc81ab3b0160e82d7863b3e6417f5 pointed me in the right direction although the instructions there caused the inclinometer to be re-calibrated in my car. I had to tinker around and I figured out that if I pressed "mode", it switched to compass calibration.
Regards,
danls
Apr 22, 2010 | 2001 Toyota Land Cruiser
How can i calibrate my phone
iPhone 3GS has a built-in digital compass that works just like a magnetic needle compass. The accuracy of digital compass headings can be affected by magnetic or other environmental interference, including interference caused by the close proximity of the magnets contained in the iPhone earbuds. The compass may need to be calibrated from time to time. iPhone 3GS alerts you whenever calibration is needed. To calibrate, hold iPhone 3GS in your hand and move the device in a figure 8 motion until the calibration screen disappears. The digital compass should only be used for basic navigation assistance and should not be solely relied on to determine precise locations, proximity, distance, or direction.
Nov 14, 2009 | Apple iPhone 3G
Etrex vista cx
Hi, the DOT (Direction Of Travel) arrow will only appear on the Compass page when you are navigating.
  1. Go to the 'Main Menu'
  2. Select 'Find'
  3. Select 'Waypoints'
  4. Select a waypoint
  5. Select the 'Go TO' button
Once you are on the Compass page you should have the DOT arrow as long as you have a sat lock.
Jun 22, 2008 | Garmin eTrex GPS Receiver
Garmin eTrex Vista HCx Handheld GPS Receiver Logo
207 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
