Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
Faulty pegasus toilet
I have 3 pegasus toilets 2 are not working because the cable that connects the handle to the control valve breaks. The cable has a small roung ball attached to one end. This ball comes off the cable and when you turn the handle nothing happens. I can't get any replacement parts from the place of purchase (home depot) any suggestions
  • 21 Answers
A local plumbing supply company with have acsess to a company called master plumber wich will have your part.  you can also go on line and talk to the manufacturer and complain.  they might send you the parts for free.
Posted on Jun 23, 2009
Where can I get a fill valve for Pegasus toilet
Use a fluid master universal fill valve, if it fits the tank. It will work as long as no part of the unit rests agains the side of the tank, if it does it will keep the float from rising.
Jul 03, 2014 | Pegasus Technologies Two-Piece Round...
My toilet handle turns but the toilet won't flush. i heard a snap and then it didnt turn to flush
Your attachment to the flapper valve broke...it is either a plastic connection or a metal chain type connection...easy fix.
Please rate me
Oct 13, 2010 | Pegasus Technologies Pegasus Elongated...
Pegasus toilet tank Model # 840565. Handle is cheap plastic and breaks about once a year. Super glue works OK, but would like another handle. Can't seem to find it on the web.
You should be able to procure a side mount toilet tank handle at most any of your local plumbing supply store, it shouldn't have to be 'Pegasus' brand.
Aug 23, 2010 | Home
Handle for toilet
Pegasus Plumbing co.
2455 Paces Ferry Road
Atlanta, GA 30339
888-328-2383
May 18, 2010 | Pegasus Technologies Two-Piece Round...
Parts for duel flush
Your going to the wrong store instead of home depot Try Ace hardware they will have the parts you need there.Also some of the new toilets have a flapper valve that has a hole in them and they don't work very good so replace the flapper valve with one without a hole in the flapper and one that has a float on it this way the float will hold the toilet open long enough to flush and not stop in the middle of flushing. The handle should be a standard handle. If you need more help ask and I will give you more information.
Feb 05, 2010 | Pegasus Technologies Two-Piece Round...
My toilet handle keeps breaking off
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada! 5-6 weeks I can poop again !!!!
(pegasus, home depot side handle toilet)
Nov 27, 2009 | Pegasus Technologies Two-Piece Round...
Pegasus toilet tank will not refill
Most likely the washer came off and is stuck in the shut off valve or the float is stuck all the way up. Checkk adjustment screw in the top of the water control valve to make sure it is not turned all the way in.
Sep 26, 2009 | Pegasus Technologies Elongated 2 Piece...
Plastic under flush handle stripped.
If the threads are not stripped on the nut or handle it should be fine. IMPORTANT TO KNOW!!! These are left handed threads, Meaning they tighten up the opposite way of a normal nut and bolt. If the threads are bad or damaged, you will have to purchase a new flush handle. They are not expensive at all. $2 - $10 Dollars. But first try screwing the nut on by turning it to the left instead of the right.
Dec 31, 2008 | Pegasus Technologies Two-Piece Round...
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
507 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
