Question about Whirlpool Washing Machines
Hot and cold water mixup
I have an estate top loader washer (ETW4300TQO). Cold water fills with hot water sometimes, I have turned off the hot water to washer and turned only the cold water on and nothing comes out, when I turn the knob to hot water the cold water comes out. My husband has checked the hoses and it is all installed correctly as far as he can tell. Can you help?
    Scholar:
  • 63 Answers
Switch the lines and grin and bear it!!
Posted on Jun 20, 2009
I have an Estate 8cycle 2speed washer that won't fill unless the temperature selector is set to Hot/Cold. Any ideas on what I need to check first?
I bet If you switch the water hose around it will fill on cold and not hot. Reason I think so is that hot fills and doesn't use the cold line. So either you got a bad cold valve or a blocked screen. Also Try to run the hoses into a bucket and see if they run well to eliminate the water source.
Jul 29, 2013 | Washing Machines
ESTATE etw4300TQO washer runs water for 30 seconds and then shuts off
1) test the timer for defective, however clean the contacts, loose wires or broken repair see the diagram
2) lack of cold water, fix it.
God bless you
Jul 02, 2012 | Estate Top Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
123 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
