Hitachi rear proj TV, light blue vertical streak center screen, moves slowly
All chanels have light, bright, blue streak which moves slowly (changes) in center of screen. Streak appears to begin from top of screen, sometimes if you look closely you can make out some lettering in the streak.
  • 1 more comment
  • Michaelroger Nov 04, 2007
    Hitachi LCD rear projection TV Model # 55VS69A. Thanks for trying, the blue streak stays about the center of the screen, it is not a source problem, my DVD player and my DVD recorder playback have the same problem. THANKS AGAIN.
    Forgot to tell you set is less than a year old.
  • M2BUELL Nov 09, 2007
Had this problem fixed. It is a common problem caused by dust brought in by the fan into the projection area of the set adjoining the projector lamp.....had to be replaced .... EXPENSIVE!
Posted on Nov 21, 2007
  • 1,694 Answers
Sounds like a source problem. What happens when you play
a DVD or some other source??
Need more info? Always give Model # and age----T.
Posted on Nov 03, 2007
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as should see an access door refer to owner book of the correct model and you can replace may cost around $200 and avaiolable at encompass parts .com Hitach distributor
Jun 06, 2010 | Hitachi 50UX57B 50" Rear Projection...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue haze/cloud in center of screen, slowly spreading
how to fix my problem Blue haze/cloud in center of screen, slowly spreading .but last time my lamp broken I order by my self and fixed now I have the blue color in my screen please let me know what is the problem may be I need to replaced same parts please let me know how to fix thank you
May 13, 2009 | Hitachi 55VS69 55" Projection HDTV
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Need to move a 57 inch hitachi rear screen proj TV
No, do not attempt this as you will damage the unit if you try to take it apart and reassemble it. They are not built for dis-assembly and re-assembly. They are easily damaged. Rather, rent a large industrial hand truck and use several straps to secure it to the hand truck and about three men to help you. It is about the only way to do it.
Be careful... there is a fragile mirror inside which can be broken if bumped abruptly.
Jan 26, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Hitachi lcd rear proj 50c1o
bad optical engine----bad luck---$$$$$
Jan 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
284 people viewed this question
Top Televison & Video Experts
