Question about Visonik V408XT 250W x 2 Car Amp Car Audio Amplifier
Amp in protect
I read others about breaking down the amp do to overheating, but the amp goes into protect with just the remote and ground wire in (not even 12+). The only way I get it to work is having a wire run from the 12+ to the remote, but it sounds like ****. The (white) power button flashes when playing, is this thing really 400 rms because my HiFonics pushed this one 10" sub hard and this is about 15% of that. Any idea of what the problem is please let me know.
P.S. I had the remote,ground, and 12+ professionally installed and worked fine on my other amp before I blew a power circuit (I believe)
  • CUTTER4LIFE
    CUTTER4LIFE May 11, 2010
    WHEN BLOWING THE OTHER POWER CIRCUIT DID YOU FIND THE PROBLEM BECAUSE IT BLOW FOR A REASON AND WHEN HOOKING UP SPEAKER ARE YOU BRIDGING BECAUSE NOT ALL AMPS ARE MADE FOR THIS BUT USUALLY CAN TRIKE IT TRY REVERSING THE WIRES FOR THE SPEAKER OUT-PUT ONE CHANNEL ON POS. AND ONE CHANNEL ON NEG. OR VISEA VERSE TRY A POS. WIRE FROM THE BATTERY INTO A FUSE THEN STRIGHT TO THE AMP WITH NO OTHER BREAKES IN IT LESS CUTS AND CONNECTIONS THE BETTER AND MAKE SURE YOU HAVE THE RIGHT GAGE WIRE ATLEAST 12G.AND FUSE MAYBE 25A
  • 26 Answers
DUDE CHECK UR WIRE .... AND INSIDE UR AMP THERE MIGHT B A SHORT CIRCUIT OR UR AMP GROUND PLUG INSIDE MUST BURNT OUT
Posted on Jun 23, 2009
2 Suggested Answers
  • 10 Answers
SOURCE: My system is running hot!!!!!
your subs are the problem, not your amp, your wiring your subs paralelle, means dropping input ohmage, allowing your amp to over heat with minimal load, check the amp specs for running at low ohms, most hifonics amps are rated 2 ohms and higher, some however will run at 1 ohm, only on class b-a amps though.(competition) dropping ohmage will allow the amp to push more power to the voice coils, however the voice coils may not be rated for 1 ohm power, what ohmage are your coils rated at? do you have a min. of 100 amp inline fuse on your 1-0 awg wire? do you have internal fans? you can add mosfets to the amp but if you do so, you'll have to re-program your amps mother board.
Posted on Jun 08, 2010
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
Why is my sub heartbeating and my amp in protection mode
Sounds like a shorted speaker wire. Try disconnecting speaker from amp and see if protection light goes out- if so replace bad speaker wire. Only other issue i can think of from your short description is that you might have a bad ground going to amp or the remote power wire is bad. try running a new ground wire to a clean metallic spot on you cars chassis close to where the amp is located. Good ground = good clean sound
Mar 04, 2011 | Car Audio & Video
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
Amp goes green at first then protection.
check the impedance load or try a different ground. when you hook your ground up always make sure you sand the metal down before you connect to ensure a good and clean connection.as for the impedance, make sure your subs are wired to the right ohms. for example, if your subs are wired to 2 ohms or even 1ohm, and your amp is only 4 ohms, then it will do exactly what your saying it does.
Sep 19, 2009 | Car Audio & Video
My amps protection circuit keeps cutting on and off when i hook up my amp
Hello m_george191,
Usually an amp will go into protection when there is a problem with the wiring, impedance load, or when overheated. Immediately when hooked up, it probably isn't overheating.
Most likely, there's a short or ground on a speaker wire, an input, or a faulty ground to the amp itself. Frayed or broken insulation, stray wires shorting across the terminal blocks, and shorted voice coils can all cause the protection circuit to activate.
First check your power and ground wires. Then disconnect the speakers and inputs and see if the amp powers up normally. If the amp still goes into protection with all wires other than 12V +, Ground, and Remote disconnected, the amp itself is defective. If it powers up normally with all other wires disconnected, reconnect the inputs one at a time to determine if one of them causing the problem. Likewise, reconnect the speaker wires one at a time.
Hope this helps.
Aug 31, 2009 | Rockford Fosgate Punch P325.2 80W x 2 Car...
My amp is on protect!!!
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low. If both the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Jun 09, 2009 | Rockford Fosgate Punch P5002 Car Audio...
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Protection Light
This is almost always caused by shorted output transistors. To eliminate other possible problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Generally, an amp with blown output transistors can be repaired.
Dec 27, 2007 | Boss Riot 850 Car Audio Amplifier
Amplifier wont turn on.
Generally, when an amplifier goes into protection when you attempt to power it up, it means that the output transistors have failed.
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Oct 25, 2007 | Kicker ZX10001 Car Audio Amplifier
Amp goes into protect mode.
I would definately suspect wiring. If you can use a volt meter. Put it on the b+ to ground and see what the reading is should be 12+ then try the ground to remote wire should be 12+. If it drops below 12 volts when car starts. Recheck wires for loose connection. Also double check the wire you have the remote wire connected to. You might even want to disconnect from the amplifier and use a jumper wire from the positive terminal on the amp to remote on the amplifier and see if it stays on then. If it stays on you will have to find the loose connection or find a different wire to get remote power.
Feb 05, 2007 | Crunch V-Drive V-2800 Car Audio Amplifier
Visonik V408XT 250W x 2 Car Amp Car Audio Amplifier Logo
104 people viewed this question
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
