Question about Panasonic Microwave Ovens
My Panasonic The Genius microwave just stopped working not getting any power to display. Wondering if it is the fuse and where that would be located.
  • 6,784 Answers
HI, if this unit is totally dead, this may be a power inverter issue. there is a fuse located on this board inside the unit. you will need to gain access to this board and fuse by removing the outer cover. there should be a few screws on the outside of the microwave to remove.
Check the In-line fuse for its value. if the fuse is good, replace the power unit(inverter board)
Posted on Jun 21, 2009
My Panasonic genius sensor 1250W microwave has stop working, now are their fuses that i can check, or is there a way i can check the heating element, the microwave is two years old and is hardly use except...
Kevin,
there is a fuse that can be checked. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Feb 26, 2015 | Panasonic Microwave Ovens
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
My panasonic microwave [genius] has no power,after a power outage
Remove the cover (5 screws on rear and pull away from front) and replace the fuse at right side rear. (15amp 125v)
May 14, 2009 | Panasonic NN-T888S Convection/Microwave...
Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Jan 16, 2009 | Panasonic NN-H264 Microwave Oven
Microwave Ovens Logo
649 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
