Question about Brother DCP 115C All-In-One InkJet Printer
I keep getting a display saying replace Magenta cartridge, I have done this, and unplugged the machine in order to 're-set' but I just keep getting same intruction message.
  • verna1968 Jun 20, 2009
    :-(.....ok, thaks anyway
  • verna1968 Jun 21, 2009
    Many thanks Vortash - its all up and running again and I am a happy bunny now :-)
  • 431 Answers
Hi I am Vortash I had this with mine cleaning the base of the ink holder with meths cleared the problem , if Meths not available a good ink flush should do it .You could clean the print head base also it wouldnt hurt .. .. regards Vortash
Posted on Jun 20, 2009
    Sergeant:
  • 145 Answers
Your auto reset chip must be broken, if reset doesnt work then you have to purchase the new one
Why does my photos art C6230 all-in-one keep saying I need to replace the black ink when the back shows 100%? The printer says it is using colors to make black print
If the machine is just using magenta, yellow and cyan to make black then you get brown, not black, (that why you have a black image unit, because YMC will not make black, color system issue. unless the machine is using yellow,magenta, cyan, then black. Are you using 3rd party toner or OEM cartridges? Did you replace the cartridge before it was required?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 23, 2015 | Office Equipment & Supplies
Genuine brother ink cartridge not detected by printer on DCP J315W printer
This is a common occurrence for these machines. They can get confused when cartridges are changed before they read as empty.
To correct this.
1) Unplug the printer from both the Power and Computer and remove all cartridges closing the cartridge access panel.
2) Plug the printer into the Power only and turn on. The machine will complain about no cartridges, this is fine.
3) Open Ink access panel and insert the first cartridge (Black is most common and close the panel.
4) The machine will complain about the missing cartridges. Open the panel and insert the second cartridge in the sequence and close the panel again.
5) Repeat the process for the third and fourth cartridge.
6) Once all cartridges have been installed the printer will ask if you have replaced the cartridges. Say no to the Black, Cyan and Yellow but yes to the Magenta and it will display the correct readings.
If this process fails to read the cartridge still then there is something wrong with the sensor inside the machine which probably means new machine.
Aug 15, 2014 | Brother DCP Office Equipment & Supplies
Replaced the magenta cartridge and it still says "order magenta cartridge". How do I correct this problem?
Did you replace with an orginal HP cartridge or a reman. Either way, it sounds like the chip that tracks toner usage is bad on the cartridge. If original HP, contact HP and get them to repalce it. If remanufactured cartridge, contact the people that refilled the cartridge.
Jun 04, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
I just changed my yellow ink and printer is still saying no cartilage need to replace
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. Try to unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace.
Hope this helps. Rate if it works. Thanks
May 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
Our printer has just had a new cartridge put in, a reconditioned one and it is just saying processing and not doing anything when it prints
I replaced the magenta toner with a Dell magenta toner and after about 50 copies the machine is displaying "004-321 Restart Printer". I've done this numerous times and the message won't go away nor can I print.
Feb 24, 2011 | Dell 3000cn Laser Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Minolta CMS magicolor printer 2300W
there should be a light flashing on the printer. try pressing the button nearest to it to see if that will move the print head out in order that you can replace the cartridge
Jul 18, 2007 | HP Printer Cartridges (Complete List): ,...
Brother DCP 115C All-In-One InkJet Printer Logo
187 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
