Question about Panasonic PT-51G44 51" Rear Projection Television
Crt's what happens when crt's go bad
  • Anonymous Nov 10, 2007
    darker screen colors not as sharp
    screen dark colors not as sharp
    Genius:
  • 1,694 Answers
The quality of the color diminishes = greens aren't green,etc.
or one color may dominate = pix is mostly green.
or one or more colors are weak = pix is purple = no green.
As you see, it would be best for you to tell me what you observe
the tv doing or not doing......T.
Posted on Nov 03, 2007
Pix flickels and gets small then normal and click off and on. this happens not all the time.
Bad caps in the power supply section (look for bulged and/or leaking capacitors) or dirty contacts on the main power relay (if it is an older CRT type) are the most common causes of those symptoms.
Aug 23, 2011 | Daewoo DTQ-20N2FC TV
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
The picture on our tevion television just disappeared. We have sound, but no picture at all. this happened very suddenly in the middle of a news broadcast.
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
May 26, 2010 | Televison & Video
Shows shadow behind every image
try replacing the cable 1st, if that fails it is probably a bad CRT.
Samsung CRTs are notorious for going bad even before their warranty period has expired
Mar 28, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
After a few minutes display disappar with a verticle flash line and when again power on its normal again for a few minutes ibm15" p50 crt moniter
  • Make Sure the cable or connected properly.
  • Restart the Computer
  • As soon as you restart Tap F2 key.
  • You will get BIOS screen.
  • Check whether you have same problem on the screen. If you have same problem on bios screen. it problem with the monitor.
  • If not with the computer Software.
Please rate my response!!
Jan 29, 2010 | IBM P 50 15" CRT Monitor
The screen on my Sony wide projection tv is turning blue after a few minutes. can you help? the model # is KP-57WS500
This is a typical bad CRT. The blue CRT part number is 8-733-647-25 but they are no longer available. It is not uncommon for this eventually to happen to the other CRT's as well. The only fix is to have a technician pull the defective CRT and have it sent to a company called VDC for rebuilding.
Nov 11, 2009 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi CS-35313
If it is not a cold solder on the CRT board at the end of the tube (inside)...... then the CRT (tube) is bad. The CRT costs more than the set new.
Mar 24, 2008 | Televison & Video
Mitsubishi
Practice visual acuity technique!Examine signal pcb for evidence of CRT coolant leak.Usually circuit board can be cleaned,then replace leaky CRT--at least one w/bad seal.
Sep 28, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Veiwfinder & lcd panel
this is probobly a problem with blue CRT, either it gone bad, or a bad connection. if it happened suddenly, and not gradually, there's a good chance its only a bad connection, and the crt is fine, in this case, it shouldnt be too expansive. good luck with that.
Mar 31, 2006 | JVC GR-DVL9000 DV Digital Camcorder
Panasonic PT-51G44 51" Rear Projection Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
