I just put a new power Supply in after the old one dident work now the power comes on but theres no sound or pic and theres a high pitch buzzing sound. i have a MAG innovision MA-32EF1AC 32" Wide HD LCD TV
  • nicklarse Jun 21, 2009
    i opened it up and powerd it up then the power board that i just got started to smoke and heat up but the power comes on. is there some place to send it to be fixed?
  • 10,594 Answers
Check back light inverter board as that can be cause of high pitch buzzing sound because it generates high voltage for back light rods in LCD panel.
Thanks.
Posted on Jun 20, 2009
  • Shahid Electronics
    Shahid Electronics Jun 21, 2009
    Ok,
    Click HERE to get TV repair shop directory and select nearest TV Repair Shop for this TV.
    Thanks.
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/reuben_09f18ea112b9b936
Mar 04, 2016 | Televison & Video
I keep getting a very high pitched noise / buzzing from my TV even when volume is muted! its spoiling the viewing. its not always there but its all to frequent now. TVis 3 years old
The power supply is a switching mode power supply. They work at high frequencies. Sometimes they produce harmonics that can be heard by people. The power supply may need to be replaced if it get really bad.
Apr 16, 2010 | Philips 42PF9630A 42 in. Plasma Television
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Buzzing sound w/no pic or sound, lamp light comes on
Replaced the lamp.Buzzing sound,power supply have problem with some transformers in it.After replaced the lamp pic should come back.Power supply reqiure replacing don't know yet.
Feb 11, 2010 | Sony KDF-E42A10 42 in. LCD Television
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
High pitch squeal, buzz, no picture
Tossed the television and put a new one in.
May 16, 2009 | Panasonic Televison & Video
Power supply buzzes when power turned on
Sounds like the power supply is bad or under powered for your setup. Have a friend test it in a known working system or try a known working power supply in yours. Had this happen in a old power supply on a newer board. The power supply was good, just not powerful enough.
Apr 01, 2009 | MSI KT4V (MS-6712) Motherboard
Sanyo TV buzzing
may be a problem with power supply.
Nov 14, 2008 | Sanyo DP42746 42 in. Plasma Television
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
