Question about Ventamatic Direct Drive Whole House Fan With Univer
Whole house Fan Stops running after 10 minutes
Just started to happen - while running after 5-10 minutes the unit justs stops working. 30" whole house fan. After a period of time I can turn it back on. Never had a problem with this before and it has enough air flow, been using it for 4 years. Is there a capacitor or something on the side of the motor that needs replacing? It seemed that the belt was a little loose so i tightened the belt slightly. This did not work. It sounded like the motor struggled when turning power on as well when I was upstairs listening... If motor is bad, how much would replacement costs run?
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Posted on Jul 02, 2009
Why does my airvent whole house fan stop working intermittently?
if fan was able to run normally after a while, you may have problem with the motor starting capacitor, this gives the fan the needed kick to spin , when your fan stops working this may mean that the capacitor have already over heated, turning it off for a while will give it chance to cool off then start up again, have the capacitor checked and replaced immediately.
May 10, 2014 | Air Vent INC. 54508 36" Whole House Fan
Stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
Jul 10, 2010 | Dolphin Maytronics Diagnostic Robot...
5,200 BTU unit. Compressor and fan both work when first turned on, then compressor quits after 5-10 minutes of operation. Won't turn on again even after 5-minute fan-on cool down. Process repeats after AC...
this could be just a simple fix of cleaning the condenser coils. If semi-clogged, it can cause higher than normal pressures and cause the compressor to cut out on it protector. Check it out.
Jun 11, 2010 | Heating & Cooling
Starts fine & stops in 3-5 minutes or driving in 1-3 miles.
Did you replaced your whole distributor or just the cap and the rotor? Have you check the pressure on you fuel line it could be your fuel pump.
May 16, 2010 | 1993 Plymouth Colt Vista
The 622 just stops playing, then you hear a
Sounds like a hard drive failure. Contact Dish Network for warranty/repair info.
Dec 15, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Ventamatic Direct Drive Whole House Fan With Univer Logo
331 people viewed this question
Top Ventamatic Dryers Experts
Marvin
Marvin
Are you a Ventamatic Dryer Expert? Answer questions, earn points and help others
