On my other TV I was able to use Native resolution on the HD Tivo menu, however with this TV it only appears to accept 480i. If I choose any resolution other than 480i, I get a black screen with the sound coming through. I am fairly certain everything is hooked up right, and the cable card is getting the 1080i resolutions to the Tivo. It just appears that this TV will not display anything but 480i. What am I missing?
Comments:
Jun 20, 2009
- Sorry I wasn't clear on that. I am using component video cables, so that should not be the problem.
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
My tv screen goes completely blank after about 5 mins..sound still works but can't see...
(More)
My tv screen goes completely blank after about 5 mins..sound still works but can't see anything..only about 3yrs.old.
i turned the tv on and i see different color stripes behind the logo, then when cable comes on,...
(More)
i turned the tv on and i see different color stripes behind the logo, then when cable comes on, everything is very dark, blurry and too high contrast. I tried watching a dvd, and the picture quality is the same as described above. I've had the tv for almost 2 years and never had that problem
Have a Hitachi 60SDX88B and does not turn on, front power red led is ON.
NO picture or sound. The...
(More)
NO picture or sound. The red power light goes ON and the green lights inside of TV are ON,
but nothing is working on the screen
Removed back cover and the three projectors are not lit then check the power supply led's
(D919, D920, D928, D930 D971 all green are ON. Red led D908 is ON).
Horizontal board red PROTECT LED is blinking. If I unplug AC cord and wait like 1 minute then power on
the green led's
DP15, DP19 , DP20, DP21 and DP22 tun ON and then DP15, DP19 , DP20, DP21 go OFF while DP22 is on.
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the...
(More)
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the exact same problem and TV as you, and I fixed mine by leaning it forward. I think there may be a leveling safety feature for the screen, and it gets out of wack. So maybe try leaning it back and forward until you find the sweet spot.
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent...
(More)
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
