Question about Maytag MDG7600AW Gas Dryer
GE Gas dryer. Not hot enough to dry clothes this week.
Vents not clogged. Blower working well. Lint filter is clean.
Gas flame seen a few seconds after dryer is first turned on and stays on for a minute or two. Exaust air gets hot. After a few minutes the flame goes away. But when it is time to re-ignight, the Ignighter glows brightly, main gas valve not engaging. Hear a relay or solinoid click then ignighter goes off. 20 seconds later the ignighter is lit up again but after about 10 to 20 seconds I hear the click again and then the ignighter goes off. The ignighter was replaced a few years ago. Model DDG7580 VALFA
  • Anonymous Mar 21, 2014
    Dryer runs but does not get hot. Four months ago we had the thermal fuses replaced and that fixed the issue. Now it has the same issue but now I also hear a low grinding sound followed by a single click from underneath the unit. Almost sounds like the ignighter trying to start.
    Sergeant:
  • 212 Answers
Replace burner assembly
Posted on Jun 20, 2009
Gas dryer throws reset after a few minutes
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Apr 07, 2015 | Dryers
My lg gas dryer will run alright just will not dry clothes.The flame will ignite for maybe 10 seconds or so and then shuts off.It keeps repeating. I know it sounds like my flame sensor needs cleaned.
I would check the vent and be sure it is open and free of lint. That would be the easiest thing to check. If you have the flexible white duct replace it, it is a lint trap.
Apr 02, 2015 | LG Dryers
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
It takes 2 or 3 cycles to dry clthes, has been going on for some time
That's typically an indication that air is not moving through the dryer. Check the dryer screen, make certain that it's clean. You may need to remove the back and clean out any dryer lint. If the dryer vent is long, it may have filled up with lint, restricting air flow. You may need someone to clean that for you.
Feb 06, 2011 | Dryers
I have a kenmore gas dryer 110 it doesnt dry the clothes the burner goes on then of stays worm not hot check the fuse its ok the igniter works also dont know what else to check
if the flame is liting but stops after 15 to 30 minutes you have bad gas coils.if the flame is liting and clothes are not drying you have to clean out the dryer and the vent line.remove the vent line,if it's a long run to the outside i use a leaf blower to blow out the line,check the outside and make sure nothing is blocking the vent like a screen or cage,if there is remove it and don't put it back after you blow out the line,then clean out the duct that the lint filter slides into,if filter is on top the duct is in the back,remove the front panel and vac out all the lint in the cabinet where the motor is.number one problem with dryers is lint build up,all a dryer does is move air,if it's clogged with lint your gonna have problems.send full model number next time and let me know how you make out,if you need more help let me know
Jan 22, 2011 | Kenmore 74602 Gas Dryer
I have cleaned out the vents to my dryer. And it still will not dry in one cycle. It takes 3 to 4 cycles before it will dry. It tumbles the air is strong and hot in the back
Hi.
Check if there is heath. If air is completely cold, check the heating element (in case of electric dryer). Heating element is tested removing it from appliance and reading Ohms with a multimeter to ensure it has continuity.
If there is heat, or if air is cold and element is good, test and replace the thermostats, there should be two or three of them placed in heating group and air ducts.
First ensure you have checked filter, vents and duct and removed lint.
If you want to contact an authorized technician call the number listed on the owners manual or on manufacturer website.
Jun 27, 2010 | Dryers
I have replaced the thermal fuse but is still taking along time to dry the clothes
The thermal fuse would only reactivate your heating system and is not directly related to the dry time cycle. Make sure your lint filter is clean and the path out via ductwork is free from obstructions ( including the end flapper outside) any retriction in that duct would prolong the dry cycle since air cannot move fast enough thru the system. A quick test would be to turn the dryer on without any clothes in it and check for a robust flow at the exot point of the duct outside... if it is weak, then the blower may be clogged, the ducts may be clogged or restricting air flow of lastly... the heater element may be on its way out... if electric dryer... or gas burner may not be opening fully to allow max flame for heat.. A few ideas to resolve your problem.. hope that steers you in the right direction...
Feb 01, 2010 | Kenmore Dryers
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Maytag gas dryer taking too long to dry clothes
Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
Jan 19, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Dryers Logo
430 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
