I feel as if I am stripping the cogs on the dial when I turn it to each setting. What is the correct way to use it. It is a second hand machine and there was no instruciuon booklet
    Brigadier General:
  • 3,917 Answers
Please check out this video which helps you to understand how to use and work with a washing machine which includes the dial settings. Donot worry about models as the use is same with all washing machines.
http://www.videojug.com/film/how-to-use-your-washing-machine
or If you love reading then :
  1. Read thoroughly your washing machine owner's manual. These instructions are designed for your particular washing machine. If you don't have an owner's manual, read the button control labels on your washing machine to get an idea of what they do.
  2. Step 2 Sort your clothes. You should wash white or light-colored clothes together and dark-colored clothes together. Clothes should be further sorted according to their material. Heavy fabrics should be washed together and light fabrics should be washed together.
  3. Step 3 Add detergent to your washing machine. Follow the instructions on the detergent box. The detergent should go on the bottom of the washing machine unless your washing machine instruction manual specifies otherwise.
  4. Step 4 Use the special bleach or fabric softener dispensers for your particular washing machine, if you are adding bleach or fabric softener. Otherwise, follow the instructions on the bleach and fabric softener packaging to find out how much and when you should add them to the washing machine.
  5. Step 5 Load your clothes loosely into the washing machine. Load the laundry as high as your owner's manual specifies or to the top row of holes in the tub.
  6. Step 6 Close the lid and set the controls of your washing machine according to what you are washing. Use hot water for only white cottons. Use warm or cold water for colored fabrics. Set the other controls according to the weight and durability of your clothing.
  7. Step 7 Turn on your washing machine. Allow it to work through all of the cycles and turn itself off before you unload the washed laundry.
Thanks for contacting Fixya.
Posted on Jun 20, 2009
Gaggia titanium inside cog won't line up with brew units cog, the brew units is in the correct possision. Machine comes on some one said I need a new ct board
If you've had the back off it may be this.....there are two grey plastic prongs sticking out of the back of the casing, when you've put it back on they haven't gone into the two lugs that are on the back of the cog, this affects the two cogs lining up.you may have to pull the cog up a little to line them up when you put the back on, the cogs should line up again as long as the prongs have gone into the lugs. Hope this this helps.
Oct 17, 2015 | Gaggia Titanium Espresso Machine
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
Dial won't set
you can possibly remove the knob itself, and see if you can turn the dial itself. if you can, then you can probably see the knob is broken. if if the shaft turns, but doesn't move the gears, then you will just need a new dial switch.
Nov 19, 2013 | GE Profile WPRE6100G Top Load Washer
Top stitch looks great, under stitch bunches. I have rethreaded, rebobbined, changed tension. same result. :(
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Aug 30, 2011 | Singer 4423 Sewing Machine
How does calender works?
Normally, the dial on the right hand side of the watch has two modes when it is unscrewed- time and date. Pull out on the dial until you hear or feel a small click. Turn the dial a little; if it moves the hour and minute hand then you need to pull out again. When on the correct setting, turn it until you have the date on the right number!
Jun 01, 2011 | Orient CEUAA002WW Wrist Watch
Chain slips on front cogs - half a turn on larger cog followed by half a turn on smaller cog - therefore unridable. The front cogs are warped ,moving left & right when being turned. I have got full...
I have straightened a large cog with a big screw driver, putting it through the outer part and levering against the inside. The metal of the cog bends quite easily and you need to work carefully, checking and correcting from the appropriate side as you go along. Your friends can stand and marvel at your brilliance, you don't need their help.
Mar 27, 2011 | Cycling
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    I have been married for 50 years, I know how to sort laundry. I needd to know WHY when the dial is turned it sounds as if I am stripping the cogs on the dial. IS THIS SOUND NORMAL.
    A lot of new style washer /dryers have a slip/clutch feature ,the teeth may be worn out on the knob .email name /model # if you need knob.Dose your timer have a metal or plastic shaft?this could present a whole different set of problems.Possible timer issue.
    Jun 20, 2009 | Washing Machines
    Washing Machines Logo
    96 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
