Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Dim lites at end
I have 13 /18 watt post lites around pool, the first 6 lites are bright and the balance loses voltage as the lites are dim....HELP
    President:
  • 1,723 Answers
You have a bad case of 'voltage drop my friend. Your transformer is probably undersized. Add up your bulbs and you have 234 watts. You're probably using a 200 watt x-former, right? Either lower the bulbs wattage to 11 watts, or get a 300 or 400 watt x-former.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
Mits colt display dims when lights are switcded on
have battery load and voltage tested and check that voltage output of alternator is adequate while engine is running with headlights on
Mar 15, 2016 | Cars & Trucks
Why did lights go dim and battery died?
Search Results
    Battery Dead, runs but headlights dim - Polaris ATV Forum
    www.polarisatvforums.com > ... > Polaris Phoenix
    Jul 23, 2011 - Go Back · Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix ... Two days later the battery was dead. ... run ok, but the lights weredim and they did not brighten with I rev'ed it up. ... Polaris ATV Legend. Polaris 2500 winch draining battery
    Jan 9, 2014
    No Electrical Power when Key is turned. New Battery
    Dec 18, 2013
    elctrical nightmare!!!
    Feb 19, 2011
    Slowly Losing Power Only when hot...
    Oct 13, 2010
    More results from www.polarisatvforums.com
    Headlights dimming - ATVConnection.com ATV Enthusiast Community
    atvconnection.com/forums/polaris/326484-headlights-dimming.html
    Apr 25, 2010 - The lights on my 99 Sportsman 500 go from bright to dim all the time and I ... did you check the voltage yet when they do thid to make sure it's still putting out ... The Rectifier is my guess, I rode my ATV with a dead battery for a ... Battery Help
    Sep 6, 2014
    dim lights at idle - Page 3
    Dec 6, 2012
    2001 400 4x4 (manual) electrical problem(voltage)
    Aug 17, 2005
    Rancher Ignition Problems
    Dec 10, 2003
    More results from atvconnection.com
    charging issues - Honda ATV Forum
    www.hondaatvforums.net > ... > Honda TRX
Feb 03, 2016 | ATVs
I have 2 hots from 240 raceway and common neutral a 250 watt bulb on 1 hot a 40 watt bulb on other hot cut neutral wire they stay on but 40 watt gets bright the 250 watt goes dim why is that
You change circuit from parallel to series..
In parallel (with neutral connected) each bulb receives full voltage, and then each bulb runs at watt rating.
In series (with neutral cut) the circuit is still complete through the two hots... except the voltage drops after each bulb... which affects the watt output on each bulb.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 17, 2015 | Hardware & Accessories
I have a mini max 200m pilot is lite but it won't lite pressure value is replaced all connection are cleaned please help
make sure it has enough flow and also voltage at pilot generator (red and white wires from pilot). should be around 500millivolts for the gas valve to open.
Aug 20, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
2007 Yukon XL, 1500 SLT, 4WD, headlights randomly go bright to dim and back very quickly
Yes this can be a normal condition caused by load being applied to the headlights and that lowers the voltage, the lites dim, then the load is removed and the lights brighten. Typical loads that cause this are AC climate control related. Have the Alternator load tested to confirm there is no problem in the charging system. Also have the battery tested, a battery that is starting to fail can cause this problem as well, a failing battery takes a huge amount of charging system power to keep it up, so that makes the lighting see higher spikes in voltage
Sep 18, 2012 | Cars & Trucks
Power into unit ok power comming out of unit is very dim.
If you have a volt meter, check the voltage, I believe it is supposed to be 12 volts.
Are your bulbs the proper voltage rating, that is 12 volts.
Do you have enough bulbs connected to the transformer, connected load should be close to 121 watts when you add up all your bulb wattages.
Don't confuse volts with watts. The transformer reduces voltage to 12 volts, but the wattage of the transformer is 121 watts. Each bulb must be 12 volts but wattage (brightness) can vary depending on the fixture from maybe 7 watts to over 50 watts.
Dec 01, 2010 | Intermatic Malibu 121W Power Pack...
Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Sep 30, 2009 | Televison & Video
The battery keeps going dead in my 03 z71, only thing out of place is i cannot shut off the headlights manually anymore,it's stuck in auto. Alternato is fine and so is the battery, drains iin about 7...
Well if lights are not staying on then you have a draw of power somewhere. Easy way to find out is volt meter. You take off negative cable and put one end of meter to battery post and other to wire dont let the wire touch post or anyother metal of vehicle. Then go through your fuse box and pull fuse's one at a time until you see voltage on meter drop. Meter should should a (-)negative voltage at start and get smaller when right fuse is pulled take notes and pull all one at a time and replace back in orginal spot. If you find one that really lowers the negative voltage draw on meter good chance you found where problem is. Id start by checking all interior lights first, including glovebox.
Sep 12, 2009 | 2003 GMC Sierra 1500
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
198 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
