Question about Garden
Engine running too fast
While mowing with lawn tractor, the engine suddenly went wild. RPMs seemed to double. I quickly shut down. Each restart results in the same high rpms. Throttle moves freely, but has no effect on the engine. Any ideas?
  • 69 Answers
Have someone check the govenor on it. Sounds like it is mesed up
Posted on Jun 20, 2009
How do I keep my 2510 John Deere tractor to not stop running when it gets warm?
I am sending you an article from homeguides.sfgate.com but they don't mention the first thing I would suspect until the end of the article, which is the coil.
" It can be puzzling when a lawn mower starts easily and runs fine for a few hours, only to stop with no warning. This sudden shutdown can be caused by an overheating engine. Reasons for an engine to overheat and shut down include debris clogging the area around the engine, low coolant levels, a problem with the oil, or an engine mechanical breakdown.
Sponsored Link Consumer Reports Website Find the Top & Worst Rated Products Unbiased Tests, Ratings & Reviews consumerreports.org/Reviews Debris Buildup of grass, twigs, and other debris that block air from reaching the engine can quickly lead to an overheating lawn mower. Debris in the engine cooling fans, engine shroud, air intake screen, grille and/or side panels prevent air circulation that would normally keep the engine cool. If the engine gets too hot, it will shut down and may be damaged. In some cases, the buildup of dry grass may catch on fire. Remove grass clippings from the engine area regularly to prevent this problem.
Low Coolant or Oil Some lawn mowers use liquid engine coolant to keep the engine from overheating, much in the same way as a car. For these mowers, check the engine coolant before each use and refill as necessary. Engines also require lubrication from oil to prevent overheating. Check the oil levels when the engine is turned off and the mower is resting on a level surface. If the level is below the "full" mark, add fresh oil. Ideally, check oil levels after every 20 hours of use, or each time you use the mower.
Loose Fasteners If a mower dies when the area around the engine is clean and oil levels are correct, there may be a problem with the fasteners in the engine. Begin by checking the carburetor mounting bolts and the bolts located where the intake manifold and engine block attach. Popping or puffing noises near the engine head may indicate that the head bolts are not tightened far enough. If noises seem to be coming from the exhaust system, check the exhaust valve. Tightening any of these fasteners that seem loose may solve the problem.
Engine Maintenance Certain problems that cause a lawn mower engine to overheat and shut down require more extensive maintenance to correct. Routinely check engine parts, such as shrouds and cooling fins, for damage and replace as needed. If the engine will not restart until it cools down, the exhaust valve or valve seat may need to be replaced. The condenser and engine coil can also cause overheating if they start to go bad. Maintenance on these systems can be performed at home by removing and disassembling the engine to replace damaged parts, or by taking the mower to a qualified service technician."
I hope that helps! :)
I I
Apr 19, 2015 | John Deere Garden
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Hello when mowing i have to run full throtle to get blades to spin fast enough to cutt good 24 hp 46 inch cutt
You do not have a problem. Air cooled small engines are designed to be run at full throttle in order to mow correctly and to cool the engine properly. Running it as less than full throttle will cause the engine to overwork and possibly overheat thus shortening it's life. It will also not cut properly as you have found. The engine has a governor that prevents you from running it too fast. Run the engine at full throttle at all times when you are mowing which is the optimum speed for proper operation. You may think you are helping your engine by running it slower but in reality you are harming the engine. It is air cooled, not water cooled, and needs the revolutions in order to cool itself properly. Also use 100% synthetic oil in this air cooled engine for more protection. Change your oil/filter once a year or every 50 hours.
Apr 03, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
19.5 Briggs & Stratton dies while mowing
the engine is getting to hot or the oil level is to low check to make sure the engine is getting the air that it needs while running they have air vents in hood as well as on sides of most of those tractors or i would mow for a while & put in a cool place to cool down if i can further help e-mail me wade at wadembly@aol.com
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
JD Lawn Tractor L130. will not start
They have an auto shutoff for low oil, start there check your fluids. If Ok check for spark. Try full throttle choke off in case it might be flooded. See if any of that works and let me know.
May 10, 2009 | Garden
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
