Question about Marvel 6BAR-BD Beverage Cooler
The door handle is loose. How do you tighten it?
IT looks like the door handle is held in place by a screw or bolt on the inside panel frame. How do you get to that as I could not find any way to remove the panel on the back of the front door??
How do you remove the handle to get to the screws to tighten the handle its very loose
Hello Martin;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on the upper inside wall of your fresh food section. So, I can not be accurate in regards to your unit.
1.) Inspect your handles. Are there 3/32" allen wrench screws at the top and bottom? If so back off the screws until the handle comes off. Then tighten the screw on the refrigerator door. Put handle back on the and tighten the 3/32" screws.
2.) No external screws - Then the handles are held on in a slip in slot fashion. Pull up on the door handle. This is going to take a little mussel. Remove the door handle. Tighten the screws on the door and the back of the handle. Slide handle back into place.
Mar 25, 2015 | Refrigerators
Inside door handle is loose. how to fix handle on my 2003 kia Sedona mini van?
you need to open the inside door and check for loosing screws or anything that looks loose or out of place
Oct 11, 2013 | Kia Sedona Cars & Trucks
Remove driver side door panel
In any of my knowledge, I would check the inside door handle for any screws, some pieces of the panel can cover up any hidden screws that keep the door panel held in place. once u get the coor panel loose, you have to most likely unhook the door handle from the panel, then go around the outside edges of the door panel with either a putty knife or a panel remover tool and pop the panel out at each held in spot. Once u get the panel off the frame, unclip the power windows connector. That should be everything.
Jul 15, 2012 | 2012 Hyundai Elantra
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
Can't get door open, so can't remove panel to fix door open prob
These door panels are held in place to the interior door frame with push-in fasteners which are located around the side and bottom perimeter of the panel. These fasteners are popped out by placing a screw driver or other flat tool between the panel and the door frame. Usually there are screws and/or small bolts which hold the arm rest and door handle portion of the door panel. You need to locate any of these first and remove them. some screws/bolt heads may be hidden by small plastic caps which cover the heads. In some models, there is a piece of molding which is snapped in around the handle or on top of the arm rest. Once the perimeter fasteners are loose and all screws are removed, the panel is lifted up to disengage it from the bottom window frame. Be careful not to move the panel too far away from the door frame until you disconnect all wiring connections on the back side. Those nylon buttons that hold the panel in place sometimes break off when you remove them. They are replaceable(auto parts store).
Aug 08, 2009 | 2003 Nissan Maxima
1997 Buik Century-the handle on the driver side door is loose. I assume I need to remove the inside panel to tighten bolts for handle.
Yes there should be a clip and or 2 small screws. sometimes it rusts, but you dont see that very much.
good luck,
Michael
Apr 29, 2009 | Buick Century Cars & Trucks
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Handle coming loose
If you only remove the 4(T20 torx) along the flat edge this will only remove the outer door panel. Start from the top and work down. Also if yours has 2 blocks that fall out, they go on the hinge only 1 way.
May 10, 2008 | Bosch 24 in. SHX36L05UC Stainless Steel...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Marvel 6BAR-BD Beverage Cooler Logo
215 people viewed this question
Top Marvel Refrigerators Experts
Marvin
Marvin
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
