Question about Denon DP-26F Turntable
Dust cover lid hinge for a denon dp26f
Price for a dust cover lid hinge for a denon dp26f
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
May 27, 2013 | Denon DP-26F Turntable
Samsung R519 laptop screen blank -apart from when lid nearly closed??
There is a tiny on/off switch, that controls the backlighting when the lid is opened/closed, located near the hinges, usually, on a laptop, sometimes the switch will stick due to dirt ,dust, loose hinges...etc. locate the switch and free it from its obstructions, if any.
Nov 12, 2012 | Samsung R519-53S Notebook
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
How do I open top of washer to replace lid switch?
If the lid is hinged along the back in line with the lid cover you just use a screw driver and pry it up from the front. SOME are not hinged and you must remove the back cover and slide lid or push lid backward to release
the clips
Oct 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Dv9000 laptop lefthand hinge cracked, lid wont shut
there is a extended warranty for known issues by hp but pc still has to be sent to u.s.
broken hinge parts can be got from ebay for buttons and dont take too long to arrive so you could have pc repaired before it even reaches hp warehouse...and for the price of a hinge would be cheaper than package price to u.s.
Jan 14, 2009 | HP Pavilion dv9000z Notebook
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
Technics sl 1210 mk5 g's
Instructions for putting the lids can be found here:
http://www.1200s.com/Service/Tech/faq.html
FYI, the dust covers on this model do not come with hinges. So, you'll have to purchase them separately.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 29, 2008 | Technics SL-1210M5G Turntable
Sl-1210mk5g's
It should be fairly obvious. The only thing I can think of it that the hinges are missing (these slot in to both the lids and the turntable and are easily lost if someone has been using them with the lids off).
If they are missing, it certainly would make it difficult to figure out!
Matt
Denon DP-26F Turntable Logo
229 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
