Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
My hayward de filter will not filter over 1 hour
I have cleaned it with acid for 48 hours, backwashed it all the fingers in it seems good. When I bump it it will put out a lot of pressure but then it starts slowing down until nothing the guage stays at 20 all the time. I can't see any leaks, don't know what else to do.
    Problem Solver:
  • 8 Answers
How much DE are you putting in it??? If it is a EC40 then no more than 4 small coffee cans of DE.
If it is an EC65, then no more than 6 - small coffee cans of DE. ( you can even shy back by a 1/2 of can of DE, without any problems.
Is the pool green??? If so, the filter will continue to plug up until clean.
Keep your Chlorine abit on the high side...DE filters run best with a chl reading of 3.0
Posted on Jun 21, 2009
My pump and filter work great for an hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
take filter apart clean grids (use TSP then 4 parts water to 1 part muriatic acid rinse off put back together then recharge with DE it should be fine filters are locked
May 19, 2014 | Hayward EC-40 DE Pool Filter with pump
Tip
Basic Swimming Pool Care
<p>Basic Pool Care Tips<br /> <ol> <li>Test chlorine and pH at least 3 times per week. Have a comprehensive water test every 6-8 weeks at your local pool store. There is generally no charge for this test.</li> <li>Operate pool equipment a minimum of 6-8 hours per day during winter months and for 10-12 hours per day during the summer for greatest overall benefit.</li> <li>Brush the pool walls and floor a minimum of once a week.</li> <li>To prevent damage to pool equipment make sure the water level never drops below the opening of the skimmer.</li> <li>Lubricate backwash valve "O" rings on sand and DE filter four times a year. Lubricate pump lid "O" ring periodically with Lube specifically designed for use with swimming pool equipment.<br /><br /><img src="water_1.jpg" /><br /><br /></li> <li>Test pH and add muriatic acid as indicated to maintain pH between 7.4 - 7.8. Never add more than 1 pint of acid at a time and wait at least 1 hour between treatments. Always add muriatic acid by dispersing into pool water opposite the skimmer and disperse as far away from the wall of the pool as you can safely reach. Use care not to drip acid or any chemicals on deck as it will cause deck etching and staining. Do not pour acid over steps, benches, or pool light. Make sure water is circulating.</li> <li>Clean waterline tile with cleaner a minimum of once a month during peak season.</li> <li>One month after initial pool start-up, add stain and scale inhibitor on a regular basis.</li> <li>Always follow manufacturers instructions on product labels.</li> <li><b>NEVER ADD WATER TO CHEMICALS</b> - Add chemicals to water.</li> <li>Always wait one (1) hour between adding different chemicals unless otherwise directed. <ul> <li><b>Filters:</b> <ul> <li><b>Sand Filters:</b> Backwash once per week</li> <li><b>DE Filters:</b> Backwash once filter pressure increases 8-10 psi above your "clean pressure" noted at start-up.</li> <li><b>Cartridge Filters:</b> Need to be taken apart and elements need to be cleaned once filter pressure increases 8-10 psi above your "clean pressure." This cleaning should be done at least a minimum of twice a year.</li></ul></li></ul></li></ol>
on Dec 21, 2010 | Pool & Spa
I get DE back into my pump strainer and I only can filter for 2 to 3 hours before pressure is up to 20 to 25 lbs and I have to use bump handle to start filter again with results
The de coming back into the pump isnt anything serious, there may be a small air leak causing the water in the filter to drain into the pump.
As far as having to bump every couple of hours... is the pool really dirty?
Is your pressure gauge broken? Turn off the pump, does the gauge drop to zero? Alot of times they dont drop to zero, so when you hit 25psi it may really only be 15. Happens alot actually.
If pool is clean and clear and the gauge is fine... have you ever taken apart the filter and cleaned the de fingers? If not, i would take it apart, rinse all of the fingers and then let them soak over night in a filter cleaner solution. This cleans them much better then a plain garden hose spray. After they soak, spray them down again, add new de and you should be good to go....
Aug 15, 2010 | Hayward EC-40 DE Pool Filter with pump
Pressure increase over the red line on pressure gauge while we were away for a weekend. Now pool is cloudy white. I am assuming this is DE. Back washed and cleaned filter twice. However, after running...
When the pressure goes up, try this. Pour some muriatic acid in the skimmer. (about 1/2 bottle) Let pump run for a little bit,(long enough for acid to get into filter)then shut off pump for 5 minutes or so. If pressure goes down to where it should be when it's turned back on, it needs to be disassembled and cleaned and then acid washed.
Jul 28, 2010 | Hayward EC65 Extended Cycle DE In Ground...
THE PRESSURE ON MY FILTER KEEPS SPIKING. I TOOK
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Pressure on the EC65 is always high
Certainly sounds like a filter problem. Here's a couple of things to try.#1. i don't know how you cleaned the filters but clean them again with a good filter cleaner/degreaser.#2. After a good cleaning, get a bucket large enough to hold the filter fingers in and give them an acid bath. They recommend a 20 to 1 ratio of water to acid (muriatic) but I personally don' think thats strong enough. Use a good amount of acid and let the fingers soak for a good ten or fifteen minutes. (always add acid to water, not water to acid) Rinse and reassemble filter. If that does'nt solve problem, I think it's time to replace filter.
Jun 17, 2010 | Hayward EC65 Extended Cycle DE In Ground...
Cloudy water
need to clean fingers with TSP degreaser then muriatic acid then they will take on the DE
Sep 14, 2017 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Hayward eC-40 pump losing pressure very fast
A better way to clean the filter tubes in the EC40 is to remove the filter tube assembly and soak it in a 5 gallon paint pail that is filled with a solution of water and a 20% muriatic acid, available at hardware and home center stores. Be very careful handling the muriatic acid. Don't splash it around.
Mix it in a 1-to-1 ratio with water and soak the assembly for at least 8 hours. Keep the soaking pail out of the reach of kids and animals.
Remove the assembly, properly dispose of the acid mix and refill the pail with clean water. Soak again for 3 to 4 hours, then reassemble your filter.
Some pool guys say it isn't necessary to soak the tubes in clean water because the muriatic acid will not harm the pool water and will reduce the pH if it's too high. I've always soaked them to be safe.
This is a link to the Hayward manual that describes the process:
www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jun 25, 2009 | Hayward EC-40 DE Pool Filter with pump
Open Questions:
See all Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP Questions
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
644 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
