Question about CRL 12" Brass Single-Sided Towel Bar without Metal Washers
12" brass towel rod/rack needed
I am looking for a small 12" brass towel rack/rod.
  • May 11, 2010
    Have you tried looking at home improvement stores or shopping online for one?
  • 34 Answers
TRY LOCAL HARDWARE STORE OR HOME
DEPOT, LOWES, ETC.
Posted on Jun 21, 2009
Vt commodore rack boots
Vt commodore steering Rack boots always rip and tear,the racks always tend to leak from the internal seals.
So if this the case with yours I would recommend you just get a reconditioned steering rack and fit it but once the rack is replaced you will also need to do a wheel alignment.
steps to change rack .
1.raise vehicle on hoist
2.remove front wheels
3.remove tie rod end split pins
4.undo tie rod end nuts and inner nuts on rack ends
5.release tie rod end from hub.
6.centralise steering wheel and remove keys from ignition
7.count the number of turns on each side that tie rod come off and write down .
8.undo the 2 metal pipes that go into the rack feed and return lines and make sure u have container under the vehicle to collect old fluid.
9.undo the 13mm nut and bolt that mounts the rack to the steering colum shaft.
10.undo the 2 *19mm bolts and nuts that mount the rack to the crossmember.
11.gentle wiggle the rack and it will come away.
12.follow these steps in reverse when fitting new rack.,make sure you replace the oring seals .
13.you will need to get a wheel alignment done..
Feb 12, 2014 | Cars & Trucks
I lost the metal mounting brackets for Ceramic/Porcelain towel bar posts and have looked everywhere. Please help
I looked for 2 weeks on google and then tried searching on bing - 1st try and I found exactly what I needed = Home Fix It Parts.com. Good Luck!!!
Mar 21, 2013 | Bath Unlimited Franklin Brass Towel Bar...
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
I need to rplace the inner tie rods.
Inner tie rods rarely if ever need to be replaced in my experience: outer tie rod ends are far more common. Its not impossible so here's how.
1. remove the tie rod ends from the knuckle.
2. remove the clamp for the rubber bellows on the rack ends, and slide the bellows down the rod.
3. Turn the rack to fullleft or right as needed to get access to the inner rod end that screws into the rack.
4. There's a lock tab that has to be bent flat. This locks the rod end into the rack.
5. You'll need a (probably) 32mm wrench to undo the rod end from the rack.
6. Note how the lock tab is fitted to the rack/rod end.
7. Put in the new tie rods.
If your garage mechanic told you the inner tie rods are worn out, I'd ask why they think so. At step 4. above, try rotating the rod. This should be quite difficult. There should be NO evidence of slop or wear in the inner joint. What more commonly wears is the bushes on the end of the rack. These bushes are easily replacable with the rack in the car.The tie rods have to be removed to do this. So, when the rods are off, inspect the rack bushes for wear.
SD
Jun 25, 2011 | 2003 Mitsubishi Outlander
My Danze brass pop-up drain assembly w/lift rod and overflow leaks on the threads that lead upto the flange. I have tried a small amount of putty to a large amount and still leaks after about 1 week from...
I always use white silicone - putty always cracks and leaks. Silicone makes a sort of custom rubber gaskit and never leaks. Clean off with paper towels immediately before it skins over
Dec 21, 2010 | Danze 1-1/4 '' Brass Pop-up Drain Assembly...
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
Left hand rack end. What is it? needs to be replaced before used on the road. How do I go about this problem?
It's part if the steering. Since you don't know anything about it, it would be best to let a garage with an alignment machine do the work.
Nov 12, 2009 | 1986 Toyota Corolla 2 Door
New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
CRL 12" Brass  Single-Sided Towel Bar without Metal Washers Logo
82 people viewed this question
Top CRL Home Experts
john h
Tom Chichester
Are you a CRL Home Expert? Answer questions, earn points and help others
