Question about Stiebel Eltron Tempra 24 Electric Hot Water Heater
Why wont steibel eltron water heater wont heat water
Repairman installed a new fan to steibel eltron heater and now it wont heat the water even though it is running
5 Suggested Answers
SOURCE:
  • 25 Answers
SOURCE: Stiebel Mini 4 won?t activate using 40l/min pump
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Posted on Jan 20, 2009
  • 234 Answers
SOURCE: Sensor broken - E 71 - Stiebel Eltron WPF water-water heat pump.
I would check the connect first may sure it is not loose.
Posted on Mar 14, 2009
SOURCE: The water heater "Stiebel Eltron
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the problems associated with your model.
I believe they offer a refund if the 'fix' doesn't work.
The manual might also have troubleshooting.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, there were same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, the brand-specific-ness of the problems, and the inability of the manufactures to take care of their customers.
If I understand correctly, the manufacturer will refer you to the installer.
There are not many ways a do-it-yourself-er can fix a tankless.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Oct 31, 2010
guitarmanjoe
  • 336 Answers
SOURCE: heating unit in a stiebel eltron electric instant hot water heater went bad and I have to replace the unit. How difficult is that?
You will have to drain the tank, make sure when doing this to OPEN the pop off valve, the little handle on the drain pipe, or the water will not drain.
Posted on Feb 21, 2013
Tonight I noticed a blue light flashing on the top of my Stiebel Eltron tankless water heater. What does that mean?
Go to the website and find the manual from your heater. In the Troubleshooting section, it tells you what the sequence of the three lights is. This is a similar model.
operation and installation - Stiebel Eltron
https://www.stiebel.com.au/products/downloads/7water supply"). Cold water flows briefly while hot water is being drawn. The air sensor detects air in the water and the ap- pliance's heating output is ..... The flow sensor (DFE) is faulty. Check the flow sensor and replace if required. Flashing green light and steady yellow light. No hot water at flow rate. > 3 l/min. The high limit ...
Downloads Stiebel Eltron
Apr 28, 2018 | Stiebel Eltron Water Heaters
Tempra Plus 29 thermal breakers keep tripping, heater will not heat water. Heater was installed last February and worked fine until a few days ago. I've reset the 3 thermal breakers a couple of times... it...
You can find this site but you can't google the manufacturer site.
If you are not able to resolve a problem please contact us toll free at 800-582-8423 before removing the unit from the wall. Stiebel Eltron is happy to provide technical assistance. In most instances, we can resolve the problem over the phone.
Dec 26, 2017 | Stiebel Eltron Tempra 29 Whole House...
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Eletric water heater not heating up to 125
Include product brand, model and type for best possible answer.
Include if this is new installation, or installation that worked before and stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 03, 2012 | Stiebel Eltron Stiebel TEMPRA24PLUS Eltron...
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Apr 16, 2010 | Rinnai Water Heaters
Water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Mar 14, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron Tempra 24 Electric Hot Water Heater Logo
210 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Thomas F. Schneider
Donni Steen
Sheldon Dedek
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
