Question about Panasonic CT-27HL15 27" TV
Our Panasonic CT-27HL15 set is only 4 years old and suddenly decided not to turn on. When you press the power button, it turns on for a second then makes a noise inside and shuts off. Any ideas is it worth it to take it to a repair shop for the $50 diagnosis?
I have one of those that is the same age and the 6.3 amp fuse was blown out. I replaced it with a 6 amp fuse (i could not find 6.3 nearby) and got a few more weeks use until the fuse blew out again. someone suggested i get a slow blow fuse next time.
Posted on Sep 17, 2009
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
SC-pt750 - screen says CT-Mode wont change
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Dec 06, 2008 | Panasonic Home Theater System System
No power on a Panasonic This TV just does not turn on now. Panasonic CT-32HL44J 32" CRT TV 4 years old. A friend of mine seemed to think this is a common problem with either Panasonic TV's in...
I have a Panasonic and after a year it did the same, this turned out to be the PCB Board(this is the master board). You may be able to pick one up on EBay possibly.
Dec 03, 2017 | Panasonic Televison & Video
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
What is a 32 inch tv V7? So I can adjust my ct-urdc6 remote.
Programming:
1- Power on Equipment
2- Press SET until device light blinks
3- Press the device button
4- Press the UP or DOWN every 2-3 seconds until device turns off then
5- Press ENTER button
Gilberto
May 01, 2008 | Televison & Video
CT-13R38SG
Parental Lock Feature
Combo's
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Turns on and immediately shuts off
check for sleep mode and whether the timer for sleep mode is on or not, if sleep mode is on lets say 30 min or 5 min , ur TV will turn off automatically after that much time
Dec 16, 2007 | Panasonic CT-32HX42 32" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Panasonic CT-27HL15 27" TV Logo
157 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
