Question about Maytag Dependable Care LAT9706
Maytag Washer Won't Run
I have a Maytag washer model lat9734aae that quit working when I lifted the lid during a wash cycle to adjust the contents. The washing machine just sits there with the "on" light lit.
    Sergeant:
  • 212 Answers
Check lid switch
Posted on Jun 20, 2009
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer worked fine all week. Today. I went to use it and I pulled the knob out to start the machine and nothing happened. Just the little red light came on. It is a Maytag top loading model LAT9734AAE
door switch look where lid closes and depresses closed swich that swich has 2 wires on it un plugg them tape them together hit start it should work
Jan 24, 2011 | Maytag Washing Machines
My Maytag washer keeps stopping during its cycle and if I lift the lit it will restart but once it starts spinning it stops. Its weird cuz somedays i can run 3 or 4 loads with out a problem and other...
On older Maytag washers the lid switch doubled as the off balance switch. If the tub wobbled too much it would trip the lid switch and this will not reset until you open the door. The idea is that when you open the door you will adjust the load so that it is not off balance anymore. I don't know if you have one of the models I am referring to or not but if so this is your problem.
http://www.appliance-repair-it.com/clothes-washer-repair.html
Oct 21, 2010 | Maytag Washing Machines
My maytag washer (about 4 yrs old) quits during rinsing cycle. I took the top off where the wires are to see what I could see. ;) The "buzzer non-adjust" zapped me when I touched it. Could this be what...
any time you touch live wires you will get an electric shock
always make sure you turn your power off before making any repairs.
more than likly the answer to your question is no that is not the reason why your washer stops mid cycle
it would either ne your lid switch causeing this and or if you can manually advance your timer to the next step. it is your timer that is failing.
please be careful
Aug 24, 2010 | Maytag Washing Machines
The lid was lifted during the wash cycle. The washer stopped but when the lid was put down it will not restart. There is power at the plug.
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Apr 13, 2010 | Maytag Washing Machines
Top loading Maytag washer Model #A9700 washer fills with water then stops, no washing, no spinning
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Jul 16, 2008 | Maytag Washing Machines
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
