Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Model PLES389ECG slide in ceramic cook top range from Frigidaire. How do you gain access to the cook top controls. (One broke during shipment and no one wants responsibility.) I removed the 4 screws from the bottom of the console assembly (318299102) which loosened it but I was unable to remove it using what I thought was reasonable force. I must be missing something? Thanks Bob B
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: How to replace the ceramic range top
you need to replace the glass top itself???that might be an expensive proposition.but heres the how to. theres 2 or3 screws along the front underside of main top. this will release the top enabling you to tip back and look underneath.not a hard job, just gonna take some patients. assuming you have the new top. its gonna be a matter of taking from one and installing on other. you will not have to undo any of the wires leading to the burner elements. instead undo the screws that are holding the elements up to the top . should be 2 brackets running lent gh of unit . undo the brackets and lay the elements down on the insulation . after removing both swap out glass and reinstall new . there will be multiple ***** holes on new glass for supporting brackets. look closely at old one for proper placement
Posted on Mar 12, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
ginko
  • 19396 Answers
SOURCE: replace ceramic glass top maytag eletric range
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 01, 2009
Scratches ceramic stove top
Good Afternoon Friend,
I understand that you have scratches on the ceramic stove top of your Frigidaire rage, model# FEF366. Small scratches do not affect cooking and will become less visible with time. To prevent any further scratches, make sure you do not use any abrasive cleaners. These can scratch your stove top even more. Try not to use cookware with rough bottoms. These can mark or scratch the cooktop surface. Try not sliding any metal or glass across your cooktop. This includes sliding your pans as well. Coarse particles such as salt or sand between cooktop and utensils can cause scratches. Be sure your cooktop surface and bottoms of utensils are clean before usage. I hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire FEF366 Electric Kitchen Range
I have a ceramic top slide in range. The clock will light up when the clock button is pressed but will not stay lit. Timer works and all oven controls work as well as the cook top and oven. Any...
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
May 21, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
I broke the ceramic top on my Frigidare Range. I
Hello, the top for your slide in would cost your $285.25 . First turn power off to the machine or unplug. To change the top you would open the oven door then remove the screws in the top near the door latch. You will have 3 or 4 screws one on the left the right and one or two in the middle section. The glass will then lift from the front and you will notice the surface elements will raise with the glass. You will have to remove the screws that hold the brackets and they you can just sit them down. Be carefull not to unplug any of the wires on the elements, and be carefull of the insulation. It will really cause skin rash. Once you have removed the elements you can lift the glass away and install the new one. I do have one new one available at my store. I can ship it to you for the price listed above. Please let me know if you have any more questions. You can also see me on ebay under the name AndersonAppliance2009
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire fes365e Electric Kitchen Range
I broke ceramic top glass ...how much thank you
We are a Jeen-Air factory authroized parts supplier. What color is your cook-top?
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Jan 31, 2010 | Jenn-Air SCE30600 Slide-In Electric...
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Replacing the ceramic cooktop on my frigidaire slide in stove
there is no need of any instruction booklet for your problem, but a cooking range repair man.
He will replace it for you.
Mar 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Replace ceramic glass top maytag eletric range
Mar 19, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Replace ceramic top on gas range
yes the part number that you need to order is 316251903
Apr 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
389 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
