SOURCE: size of sd card
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
SOURCE: CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
SOURCE: Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
SOURCE: SD 215mb memory card reads ''memory card error''
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: I have a 2GB SD Memory card thats won't format and says its full
per manual... camera supports UP TO 256MB... your camera can't recognize a 2gb card.
