Question about Maytag MZD2752G Side by Side Refrigerator
Right side of refrigerator not cooling; frezzer working great
Turned the refrigerator to coldest setting and the temperature remains cool not cold. Turned the freezer to highest setting and the refrigerator still remains cool. Found some ice buildup on back wall of freezer. Also removed the channel that directs the cold air from freezer to refrigerator. Didn't see or feel any obstruction. did see a metal coil coming from refrigerator to freezer. Don't know what that is for. Was not connected to anything on the freezer side. Seems to be connected on the refrigerator side though.
Any suggestions?
  • catfish4 Nov 06, 2007
    thanks for the help... you wee dead on with the diagnosis!
  • shrinkbob Aug 07, 2008
    freezer side works well, refrigerator side works less and less efficiently, milk is going bad, soda cans get cool, but not cold.......
My Maytag has smiler issues and they need to replace computer.. luckily I had warranty otherwise it may have cost quite a bit..
Posted on Aug 30, 2008
    Scholar:
  • 146 Answers
The coil is the thermostat that controls the damper which allows more or less cold air into the fridge compartment and should be put back as you found it. Very important. The problem is that the freezer is not defrosting, hence the ice build-up on the back wall. Either the defrost timer is faulty or the defrost heater is blown. There are two thermostats behind the freezer panel, one in line with the fan and one in line with the heater and they will be clamped to the pipework. Both these thermostats should be closed when iced up. If the fan is not running, that could be faulty too or its thermostat.
Posted on Nov 03, 2007
GE Profile - Both freezer side and refrigerator side too warm - set the the temperature controls to coldest, items in freezer no longer frozen and refrigerator side just barely cool.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | GE Profile Side-By-Side Refrigerator with...
My fridge is cool but not cold, I turned it to the coldest setting but its still just cool.....what should I do?
heatman101
May 04, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
heatman101
Mar 18, 2011 | Refrigerators
Whirlpool GD5SHA Freezer Problem: Yesterday, observed that freezer section was not keeping items frozen and the ice maker was not making anymore ice. The refrigerator section remained cold and the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 17, 2010 | Whirlpool GD5SHAX Side by Side...
The freezer is cold but refrigerator side is turned to coldest setting but it is only luke warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 14, 2010 | Kenmore 56864 Side by Side Refrigerator
Side by side, refrigerator not cooling well. go it turned to coldest setting. freezer works great
MAKE SURE THAIR IS NO ICE ON BACK OF FREZZER WALL THE FREZZER CONTOL SHOULD BE SET IN THE CENTER LIKE 4 OR C
Jan 31, 2010 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
The freezer is not cooling and refrigerator is not remaining cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
sfgmjfmkxf
Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MZD2752G Side by Side Refrigerator Logo
197 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
