Question about Kenmore Dehumidifiers
The dehumidifier runs but no waster is coming out
Kenmore Model 580.5401400 gets very warm when you touch the top of the unit. The unit runs then stops for while and runs agoin. But, there is no water going into the drain.
  • 69 Answers
Frank it sounds like to me that it needs to be shut off a while, Was there a power outage or did you happen to shut it off and try to restart it real fast. If so then the compressor can not push the freon through. let it sit for about 8 to 10 minutes so the pressure drops and then restart it. Otherwise it will just burn up the compressor
Posted on Jun 20, 2009
The top of the cabinet gets very warm and starts to smell after a couple of hours of running. I pulled off the back panel and the compressor was hot. Is that normal? If not what should I check?
Hi,The compressor is not starting... the unit is junk...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 24, 2011 | Kenmore 54501 Dehumidifier
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 19, 2010 | Kenmore 5230 Dehumidifier
Whirlpool dehumidifier does remove water
indicates a gas leak and there is insufficient gas in the system
Oct 19, 2017 | Whirlpool AD50USS Dehumidifier
Unit runs but the coils dont get cold
The compressor should be cool near the bottom and hotter at the top. If it runs but the coil is not cool, it probably lost its charge. Developed a leak and lost all the refrigerant.
Jun 28, 2010 | Fedders A7DH45B2A Dehumidifier
A one year old Kenmore dehumidifier model #580-54501700 runs but no water comes out. Do not hear compressor run. Unit powers up and fan runs.
these units are notorious for losing their refrigerant charge,if the compressor isn't running that is one reason why, have a gauge put on the system to see sealed system pressures otherwise the low-pressure switch could be bad,you can test this with a continuity meter
Nov 14, 2009 | Maytag M7DH45B2A Dehumidifier
My model LG3850A20500H dehumidifer is not collecting any water but is running. Is there anything I can check?
You can check the condenser unit, by touching it. (be carefull of hot surface) if the condensor unit not warm at all we can sure that the dehumidifier is not working, (only fan). The problem may be come from compressor or temperatur limit is not working or cooling agent is finished cause by some leakage on the tube.
Aug 12, 2009 | Dehumidifiers
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
Water not collecting in reservoir; seems to be building up in the top and running out left side (as you're facing unit)
Before I can fully troubleshoot this, what is the exact model of your Kenmore Dehumidifier. Please use the comment button to post up the exact model number.
Thanks
Jun 30, 2009 | Kenmore Dehumidifiers
Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
May 28, 2009 | Kenmore 54501 Dehumidifier
Warm air from side vents..
If your dehumidifier is one that runs at colder temps so it does not ice up, it will have a heater in it to prevent this. That is the warm air you are feeling.
Sep 06, 2008 | Kenmore 53701 Dehumidifier
Dehumidifiers Logo
74 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
