Question about ViewSonic Pro VP2130b 21.3" LCD Monitor
Viewsonic VP2130b monitor no post black screen
Have a Viewsonic VP2130b monitor. It does not show a post screen or windows, but the power light is on. It does this on all 3 of our pc's, so it has to be the monitor. Have taken out the DALAVPMB020 digtal board and the EADP-64BF B power board. Can see no overheated componets or burned tracks on either. Suspect cap or zener on power board, but don't have the tools to test them and don't want to get started in a hit and miss soldering job. Any history on the bad component?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Here is a suggestion:
By looking at the power board you should see the light, and where it is connected to, so diagnose the circut from that point foreward eliminating any potential of damging the board. try any cables or ribbons.
Posted on Jun 20, 2009
Where can I find the right driver to install a Viewsonic VE710b Flat Panel Monitor? I am running Windows 7, 64-bit **This connects to my VGA port, I already have 36" Samsung conntected via HDMI, and
Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Oct 10, 2014 | ViewSonic Computers & Internet
My screen shows start up screens but while my computer loads, i cannot view my window screen... it became black but however the power button is still green
Welcome to FixYa!
here is the things you should do .
1. download a drivers click here
2. Restart the system in safe mode and install drivers (these are up-to date)
3. Check the LCD have you plugged the DVI cable or simple VGA cable ..
3A. And if are you using any Graphic cards remove the DVI cable just use motherboard's own VGA
outlet and connect it to the LCD , if it works then you might have the problem with graphic card,.
4. Check either your LCD is displayed on 1 or 2 check the button near power button on LCD.
If it does or doesn't solve your problem do comment here ill know.
Best Regards
Apr 13, 2011 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Problem: no image, black everything, it doesnt turn on, there is no red light and no green light either, previously sometimes turn off and than went on again... it did it several times... I can buy a...
Unplug the cabels and plug it back in,Have you tried this already?
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
Had a look at a ViewSonic VP2130 with a friend of mine who used to fix TVs. He found a bad cap and has replaced it, however the LCD will still not function. We've looked at all the caps in the power...
its the J2 noise reduction. my **** did the same thing i changed it and now my **** works if u still have problem just post it here and ill go from there
Feb 08, 2010 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Won't power up
1.This could be the transformer on the power supply board that needs replacement along with a bad rectifier diode in the full bridge mode.
2.check diodes in the power supply should read .535 with the digital meter leads ( red ) on the anode and the black lead on the cathode. this indicate good is lower then the diode needs replacement.
check the internet on how to test diodes in a circuit. If you are savvy enough you will successfully repair this unit.
Jan 29, 2010 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Viewsonic VP2130B no Video
First off, on these monitors, usually the power board is also the inverter board. If its not on this model monitor, and you know that by opening it up and seeing the backlight cables connected to a different board, than that may be the problem, but it might not be.
Secondly, Why did you replace the power supply? Were you not getting anything? power light? anything at all?
If you were getting the power light, but no picture (black screen), something else was most likely the problem.
Your problem is probably the backlight. It sounds like its out. Does the backlight come on at all? If it doesn't and you can faintly see an image if you look closely or if you press the menu buttons and see a faint change in the screen, thats the problem. Normally I would say its either the power board OR the backlight, but you say you replaced the power board. You need to replace your backlight. You can do that a couple different ways:
1) Replace the whole LCD panel. This is a costly fix, so if you are adventurous and cheap like me I would advise against it.
2) Replace the backlight panel. You need a screen like yours that is broken, but has a good backlight. That way you get it cheap, because its broken and beyond taking everything apart and putting it back together again, its relatively simply.
3) Fix the backlight you have. There are tutorials on how to do this online, but its harder and more dangerous (mercury and toxins that can cause lots of damage). I wouldn't do this, but if you want to I would suggest doing it in a place with lots of ventilation.
There could possibly be a problem with your mainboard, especially if you see no image AT ALL and you don't see a backlight. If your power board/inverter and backlight are fine, you should see the backlight on, regardless of the condition of the mainboard. If you see the backlight, then the mainboard is the problem. If your power board failed, and the power light wasn't coming on before, its possible that the board fried your mainboard and potentially your backlight (although damaging your backlight is rather unlikely).
In any case, good luck to you!
Aug 13, 2009 | Computers & Internet
Need Power Supply for VP2130 Viewsonic Monitor
try ebay, i've found a few for Samsung monitors there.
Aug 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
NEED TO CHECK FOR BAD CAPS IN VIEWSONIC vp2130
To disassemble your monitor follow these steps.
1. Remove the stand, usually 2 to 4 screws
2. Now there will be screws in each corner on the back of the monitor.
3. Take a small flat blade screw driver and seperate the two halves of the case. The front and back are held together by plastic latches spaced several inches apart around all four sides.
4. After the back case is off the boards you will be looking for are under the metal shield, remove the screws that hold it on.
5. Check my web site at www.ccl-la.com , we have pictures of what the bad caps look like if you are not sure.
6. Be sure to replace any capacitors that have raised and blown tops.
I hope this helps, If so please rate my solution.
If you need more info let me know.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Open Questions:
ViewSonic Pro VP2130b 21.3" LCD Monitor Logo
1,973 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
