Question about Kenmore 44102 Front Load Washer
LG front loader not draining properly
When the cycle starts, the water comes pouring out of the soap dispenser area. When we quickly pulled it out, we noticed that the water was not draining down into the washer fast enough and was backing up out of the soap tray. We have heard about a lot of clogging issues with this washer. There are no authorized service providers in our area. We need to know how to access the water drain (into the unit, not the drain out of the unit) so that we can check for clogs.
  • 1 more comment
  • islandingram Nov 03, 2007
    Thanks for the quick response!! We don't use fabric softener, so all that was relatively clean. The problem is after the water goes through the soap dispenser, there is a "tunnel" that leads the water into the washer. That is where the water is getting backed up. It no longer drains fast enough and therefore causes the water back up into the soap tray, spraying out of the door and down the front of the machine. We believe that there is some blockage in that tunnel, but don't know how to access it.
    Thanks again!
    Island Ingram
  • glor1 Nov 09, 2007
    have pulled out the soap dispenser tray - now need to get a screw driver to take off the part that holds tray in place to see if something is blocking it.
  • Anonymous Nov 25, 2007
    Well I've had my LG Tromm since august of 07, just in the last day(2 loads), I've noticed the soap tray is full of water after the cycle ends, I pulled it out,
    it was pretty gummed up with soap(HE)residue, so I gave it a good cleaning, popped it back in did another two loads and the problem seems to have been rectified.
My LG front loader is stopping during the drain cycle (making a humming sound as if it is trying to drain, but can't....What can I do?
Posted on Sep 03, 2008
Eagle 388's solution was perfect. My fabric softener dispenser has been blocked for months. His solution worked perfectly. You saved me heaps of money, time and inconvenience....Thank you!
Posted on Nov 10, 2008
  • 4,889 Answers
First, make sure you don't have your drain hose shoved down in the drain standpipe too far. If you don't leave an air gap for the drain hose, this will often cause poor drainage problems and/or siphoning of the water as it tries to fill (this may be a cause for your soapy clothes, too). The drain hose should rest inside the standpipe so that pipe is not sealed and the hose is not sitting in the drain trap. You can check your drainage also by connecting a wet/dry shop vac to the drain hose and try to pull water through it from the machine. There will be some residual water that remains in the tub after washing. Just follow these simple steps:
1. Unplug machine.
2. Remove the lower kick plate under the door. There will be a screw in the bottom corners of the panel holding it on.
3. Find the drain pump. It will be on the right-hand side and is usually white in color. The drain hose from the bottom of the tub will be connected to it.
4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it.
5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere.
6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught.
7. Clean out the pump and drain hoses.
8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "CANCEL" button to stop. Make sure you place the drain hose back in the standpipe too.
Now...dispenser problems are usually the result of fabric softener and mildew. If you remove the dispenser tray from the machine and look inside the compartment on the front of the washer, you will notice a series of small holes in the overhead portion of the cavity. This is where water gets dispensed into the tray and flushes softener, bleach and detergent into your wash. If these holes get clogged, the tray will not dispense properly. Take a rag and clean this area thoroughly using some hot water. The water will need to be warm enough the melt any fabric softener residue that may have accumulated over time. Next, clean the area really good with some bleach solution to get rid of any mildew. You may have to use something to clear all the holes of debris. Often fabric softener is the culprit and it cakes the holes up. A simple wiping down with a rag may not be enough to do it. A cotton swap of tooth pick works great at cleaning these holes. This is also a good time to take the dispenser tray and soak it in some hot water in the kitchen sink to clean it out as well. Good luck to you and let me know if you find this advice helpful.
Posted on Nov 03, 2007
  • 1 more comment
  • eagle338
    eagle338 Nov 03, 2007
    Remove the lower front
    panel just a couple of screws usually
    #19 amd #18
    Sometimes coins, zippers, lint, bra
    under wires will get caught/jammed in the drain pump assembly and stop it from
    running/working.
    The hoses can be removed from the
    pump to check for any foreign objects or the pump ( the part where the pink and
    white wires are ) can be totally removed by unclipping the wire harness and
    removing the two 5/16" bolts to check the pump assembly itself. The pump can be
    taken apart to check inside....if needed.
    The pump assembly is in the front right corner...
  • eagle338
    here's d pic..
  • eagle338
    Also pls note that i am just a college student and may not be able to respond to your posts immediately..Pls have patience..I will always try my best to get the problem fixed but it may take some time..
    Regards,
    Eagle.
2 Suggested Answers
  • 1531 Answers
SOURCE: I own a Samsung WF338 Front loader washer. Water
you need to set this up for service
Posted on Sep 19, 2009
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
2,994 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
