Honeywell RTH2510 A/C won't work
I just moved into a condo, and the first day the a/c was working perfectly, then later that night, it turned off and I couldn't get the a/c back on. I called customer support, yet I still couldn't get it fixed. The worst part is today it got really hot, and I'm stuck without a/c. I've tried turning it off from the breaker panel, and still nothing.
  • Heating & Co... Master
  • 1,655 Answers
Check the float switch. likely a backed up condensate drain.
Posted on Oct 13, 2017
  • 36 Answers
SOURCE: Honeywell Air Purifier model 18155 simply won't turn on
Check the manufacturer's instructions here for resetting of sensors and filter maintenance:
Posted on Jan 03, 2008
  • 1420 Answers
SOURCE: Honeywell Thermostat won't turn on
There is a small automotive type of fuse in your air handler (not thermostat), check that. Also check to see if the Emergency Switch somehow got turned off (Usually found in stairwell or closet).
Posted on Aug 07, 2008
SOURCE: Sunroof
The sun roof has nylon gears that pulls the roof back and forward when activated. There is one on both sides of the sunroof track in the rear corners of the roof track housing. Unfortunately they are not replaceable by themselves and must be purchased as a unit for the whole roof track system. The cost of the replacement and labor to have it installed (if you can find someone to do it) is up to $1500 so isn't very practical to replace based on the value of the car itself. Better off to just work the broken piece out and manually put roof back in place in shut position and not use anymore, at least that was my experience with the one my daughter owns.
Posted on Oct 06, 2008
  • 6966 Answers
SOURCE: Dy/night heater turns on for 10 sec then and off, over and over
Hi and welcome to FixYa,
If I understand your concern, it is that the heater switches itself on for 10 seconds and then switches itself automatically off. A couple of ideas of you may want to explore/check:
  1. the built-in protection system detects an internal fault and to prevent any further damage switches itself off;
  2. the faults could be:
  • open heating element (assuming it is electrical);
  • blower not turning;
  • open limit switch. The limit switch is an inline cutoff to the heater that automatically opens up when the heater exceeds a pre-determined temperature independent of the settings in the thermostat. This is like a thermal fuse once gone bad will remain open;
  • whereas a thermostatic switch will turn on if temperature is below its threshold and turn off if the temperature is above. It is basically an on/off switch.
Often the limit switch would look like the image below.
To be able to provide a more detailed information/assistance, pls verify & post back the model number of the Day Night Heater. Model 8ou-19 does not turn up anything. Or perhaps you can share the website you were referring to.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
SOURCE: Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
It is a problem on your low voltage side. I had the same issue and found that my wire going to my outside condeser had been snagged on a wire hanger in my basement and was shorting out the system. I went a head and replaced the entire wire from my outside unit to my indoor and haven't had an issue since. So my advice is go to HD or Lowes and purchase some 14 gauge wire and replace the low voltage wire. If that doesn't work, then replace the thermistat wire, and thermistat. Great time to upgrate to a energy efficient thermastat.
Posted on Mar 18, 2009
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Replacing a Honeywell T822l1000 thermostat.
The W terminal is used for heating and goes to a small electric valve in the water line to your baseboard. The Y terminal is for a cooling system. The T822 is wired wrong and is not working. The wiring between R and W is corect for a heating only application. The R terminal is the power source.
Nov 10, 2013 | Heating & Cooling
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I changed a honeywell thermo last night. I'm
check your transformer some of them have a little reset button on the side if it arched it could of tripped it.if there is no reset make sure you have 24v coming into thermostat.
Apr 22, 2012 | Honeywell Heating & Cooling
Thermostat is reading FR Return what does this mean? It is a honeywell CT 3200.
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Apr 03, 2010 | Honeywell CT3200 5-2 Day Electronic...
The sideview mirror lights and windows have
I am pretty sure it is the body control module. My 02 sable is currently having a similar issue. On a random day my girlfriend took the car to the store, the car started honking when she went to re-enter the vehicle. never done that before. Later that night the left front turn signal will not shut off. the turn signal light on the dash stays on solid, this morning the bright light indicator was on solid and the turn signals worked perfectly fine until the blinker light eventually went back to on all the time. I disconnect the battery at night or if I am not going to drive it for a few hours. But I am 99% certain it is the BCM causing this.
Feb 18, 2010 | 2002 Mercury Sable
Honeywell 6300B clicking noise
I have the same model, and am also experiencing the clicking.
Jan 21, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
