Question about Sunbeam Steam Master 4055 Iron
Need to clean my sunbeam steam iron and can't find the instruction book. Help! Won't spray when I push button, can't get the clean mode to go anywhere.
  • Anonymous Mar 12, 2014
    Well one quick flick with my knife to the side of the steam button and it came out. Well the surprise was the screw under these buttons. Hopefully this can help someone looking to disassemble the iron when they have problems.descale
  • 999 Answers
Fill it with white distilled vinager and sey it in a shallow pan with enough of the same vinager to cover the shoe. Let that sit overnight then try the clean function again.
Eric
Posted on Jun 21, 2009
I have an Enduro 4500 Telfon iron, the auto light is flashing and beeping can you advise how to turn the beeping off.,
Thanking you in advance
Posted on Sep 02, 2010
The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 15, 2012 | Black & Decker Irons
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
I need the instructions to clean the iron, please. I lost my manual. Thanks!
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Apr 02, 2011 | Sunbeam 4232 Iron with Auto Shutoff
Clean button won't work
Try this unplug,then pour a little vinegar(white) and keep pushing on button then clean out with vinegar to remove hard water deposets.
Aug 29, 2010 | Sunbeam Steam Master 4055 Iron
Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Scale build up problem in iron
White vinegar and a toothbrush. You can clean the whole steam path with 25% vinegar to 75% water. Steam it through. Run plain water afterwards to rinse it out.
Feb 06, 2009 | Sunbeam Irons
Sunbeam Steam Master 4055 Iron Logo
2,579 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
