Question about Garden
Trouble un-screwing edger blade bolt
I have a craftsman edger and need to change the blade on it. For the life of me I can't get the blade bolt to budge at all. I've tried WD-40, have tried putting wratchet on bolt on opposite side and securely twisting, but having no luck getting the thing to budge. Any help or ideas would be appreciated. Was also wondering if anyone has info on sharpening the blade that is on it. OM says not too...didn't know if this is a marketing tool to sell more blades...thanks.
David
  • panilling9
    panilling9 May 11, 2010
    could be left handed threads--------------try tightening the bolt to remove it?
    you can use a angle grinder to touch up the blades as long as they are not too thin
  • 376 Answers
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Posted on Jun 20, 2009
How do I change the blade
The blade bolt is normally 9/16, you will need a good socket and long tommy bar to remove the bolt, an impact wrench will take it out very quickly if you have or can borrow one,
Jun 16, 2012 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
It's impossible to change a blade on a craftman edger. There is no way loosen the bolt holding the blade
Can you grip the blade and hold it still with say a pair of Vise Grips and remove the bolt that way? Lock the grips on the blade and then when it turns will it jam itself against the blade guard allowing removal. What type of bolt actually holds the blade on? Post back with more details.
Aug 16, 2010 | Craftsman Garden
Does the bolt on the blade come off counterclockwise or clockwise.
If you are facing the blade from where the bolt is, and the blade's normal operation is to turn counter-clockwise, then the bolt will loosen counter-clockwise. This is universally true for any blade which is held on by a center bolt (table saws, grinders, etc.) This is because the motor is turning the shaft counter-clockwise, and the resistance against the blade as it does it's work is clockwise - thus tightening the blade rather than loosening it. If the blade normally turns clockwise, then the bolt will loosen clockwise.
Jun 24, 2010 | Craftsman Garden
How do i change the blade on a craftsman edger?
also check the coil see if you get spark
Dec 13, 2017 | Craftsman Garden
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
Craftsman gas edger - lost the bolt to screw the blade on with. Need type of bolt and where I can purchase one
if it is a craftsman edger go to sears.com and go to the parts direct tab and enter the model number and look for the part you need and order it.
Oct 25, 2009 | Garden
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Mar 21, 2009 | Garden
I need to replace the starter rope on my Sears Craftsman edger. I cannot determine how to take apart the starter housing assembly. Model is a Sears Craftsman Edger Model 536.797470 Thank-you
it should be a shroud its all in 1 unit it should have 3 bolts holding it to the engine block un bolt the shroud & e-mail me or call me i will help you get a string in so you can use my name is wade 831-578-4034 if i may help ya
Jun 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
775 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
