Question about Garden
Primer will go empty. I can get no gas in it wile eng. is hot. when eng. gets cold priner will fill up by it's self
  • lazyhoundone Jun 22, 2009
    how can I get rid for the vapor lock so I doun't have to wate for the saw to cool off
    I have allso found that the gas tank gets pressure in it. When I open tank to add gas to it I get a burst of air out of it. Even with that pressure in it gas will not go throw primer till eng cool's off
  • 34 Answers
LET ENGINE COOL OFF. YOU PROBABLY HAVE VAPOR LOCK IN PRIMER.
Posted on Jun 20, 2009
  • steamman27 Jun 22, 2009
    IF YOU GET A BURST OF AIR OUT WHEN YOU OPEN TANK, IT SHOWS THAT TANK VENT IS NOT
    WORKING PROPERLY. GAS CAP WILL USUALLY HAVE A VENT IN IT. CHECK CAP, IF ANY
    DOUBTS, GET A NEW CAP.
Replaced fuel lines on my troy-bilt tiller and it ran great came back the next day gas in the lines and bulb was empty realized the bulb was cracked , i replaced the primer bulb and put everything bac
By the absence of the gas in the lines Sounds like the small hoses are cracked also, best to replace them..they do get brittle over time..best to change them periodicly... It can be a DIY job may have to loosen the carb to bend and get them on.a .very inexpensive part..and be bought at any shop or auto parts store..and not a big job for the repair shop..good luck
Sep 23, 2014 | Troy-Bilt Garden
Not geting any gas to the eng.
look in the gas tank and see if line is rotted.
next look at small filter in end of line to see if it is plugged up.
when you push the primer bulb you should see gas in it.
if not then you might have to replace all the gas lines and primer bulb.
Jun 25, 2010 | Poulan Pe550 Gas Edger
Will not start in cold weather
ITS PROBLEY NOT SET UP TO RUN IN THE COLD MOST OF THEM ARNT
Oct 08, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Gas leaking in a stream from other end of primer line
Something is causing the float in the carb to stick in a downward position. This float tells the carb when to cut off the flow, and stuck down it keeps the channel open for gas to flow through. Empty the gas and remove and thoroughly clean out the carb, making sure you hit the float bowl very well. Worst case the float could be bad. If cleaning it thoroughly doesn't get it, consider a carb rebuild kit from the engine manufacturer or replacing the carb.
May 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Cold water fill
You need to open the back and follow the cold water hose to the solenoid. Tap the solenoid a few times wile you are trying to use cold wated. If not check for power at the 2 wires that go to this solenoid, if you gout power then you need to replace your cold water solenoid. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Temp guage goes to max (right) when engine is cold.
change the themostat when you remove the old themostat you should see it stuck in the open postion . before i install the new one i fill the the block with coolant install the new stat run the mtr and heater core until hot iwould also replace the cap
Jan 01, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Garden Logo
83 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
