Window air conditioner keeps switching to fan mode. Which means on hot days it is blowing warm air. It sporadically switches to air conditioner mode. Room is hot because the cool air only blows for about 10 minutes. Help!
  • 25 Answers
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Posted on Aug 18, 2008
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
  • 20 Answers
SOURCE: air conditioner symbol defrost keeps coming up so
These will defrost themselves automatically when they need to - internal sensors. If it is icing up at all in cooling, then the charge is wrong. Units such as this are very sensitive to incorrect charge, so I would recommend that you have a qualified tech come out, recover all the freon and weigh in the correct charge. If this is a "new" problem, then a leak check/locate would be in order.
Posted on Sep 01, 2009
  • 534 Answers
SOURCE: Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Posted on Oct 17, 2009
madman775
  • 5 Answers
SOURCE: blowing out warm air when i put in cooling mode
is the compressor running? usually a louder noise? may be low on refrigerent....need guages to assess
Posted on Nov 02, 2009
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 24, 2016 | Heating & Cooling
Amana ptac during heat mode will blow hot air , then blow cold , but will cycle back to heat eventually is this Normal?
if the fan switch is in the Run position and not the auto position you are getting cool are when the heat element is not on. this is kind of like a way to circulate the air. look for an auto setting it then should only come on when needed. Keep in mind it is normal for the fan to start blowing before the heating element is warmed up, this prevents it from over heating, or coming on when the fan is not working
Nov 26, 2014 | Heating & Cooling
My tadiran split system air conditioner is blowing warm air
if its warm air like really hot then you switched the unit to heat mode
if its blowing air in room tempereture then there is a gas leak somewhere ,so you'll have to find the leak source and after that fill the unit with freon gas.
Aug 26, 2014 | Heating & Cooling
Honeywell 97-4118/5-89
probably low on freon. i assume compressor is running?
Jan 25, 2014 | Honeywell ER150B Air Conditioner
Hi, my air conditioner works fine but if I leave it on to long it will start blowing out warm air. Then when I turn it off, it sounds like its still on. And I have to wait a whole day before it blows cool...
Sounds like the unit is icing up.
Window air conditioners are not usually of sufficient capacity to keep a room much below 74°F. If not allowed to cycle off occasionally during the day, the evaporator (cold radiator) will ice-over and prevent air from passing through it.
The way most are constructed, the water is designed to drain to the bottom near the compressor. The heat of the compressor and air provided by the condenser fan motor are intended to evaporator the condensate.
Try using a higher setting on the unit and see if that helps. It needs to be able to shut-down once in a while. If you have the option, set the fan switch to 'on' instead of 'auto'. This keeps the inside fan motor blowing all the time, with the compressor cycling as needed. The moving air will make the conditioned space more comfortable with a higher temperature setting.
Jun 28, 2011 | Heating & Cooling
Furnace fan will not turn on when in "Auto" mode. If switch to "Manual" mode on thernostat, fan will come on, but doesn't blow warm air.
depending on which make aand model of furnace the heating blower relay or heating blower switching device could be bad when you switch the t-stat to manual or on that energizes the cooling blower relay is it gas or electric?
Dec 28, 2010 | Heating & Cooling
2004 chevrolet avalanche A/C not staying cold, after a while goes warm
2004 chevy Avalanches air conditioner blows hot air, can the actuator be forced to keep it blowing cold air instead of hot air all the time.
Jul 20, 2010 | 2004 Chevrolet Avalanche
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
Sep 19, 2009 | 1997 Chrysler Concorde
Wall A/C only SPORADICALLY blowing cold air. Turn it off and back on, you can feel it's cold, but only if you're 5 inches from it. After a couple of minutes, fan is only blowing warm air again. Vacuumed...
if it blows be not with force like it used to it can be fan motor capacitor not boosting fan speed. but if speed is not the issuse. remove and clean both coils water hose
Aug 29, 2009 | Heating & Cooling
Heating & Cooling Logo
673 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
