Question about Whirlpool LGB6000KQ Gas Dryer
Gas dryer tumbles but does not heat, I'm trying to locate igniter
Where is igniter in Whirlpool dryer?
    President:
  • 1,136 Answers
Hi, The ignitor is inside the dryer under the drum. The first part you will want to test is the fuse (most common problem)
Here is how:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the fuse tests ok, let me know and I can instruct you on getting to the ignitor.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on Jun 20, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Change igniter on whirlpool gas dryer
Must remove the front of the dryer. It is located in the front lower left hand corner. Check the frame sensor too. It is located next to the iignighter.
Sep 17, 2014 | Whirlpool Clothes Dryer Igniter...
Whirlpool dryer wont heat>replace igniter > no heat
Bad thermo switch located behind back cover in area of duct work. 1/4"x2" white in color, two wires connected to it. Stops ignition from firing.
Jun 06, 2010 | Whirlpool LGN2000LWH Gas Dryer
Whirlpool gas dryer model#LG5791XM- the burner is working off&on
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
Nov 14, 2009 | Whirlpool Dryers
Whirlpool gas dryer runs, doesn't ignite.
the ignitor could have a crack in it, so that it never glows.
If you have an ohm meter you can check through the leads on the end (with the wires removed)
I'm not sure but I think it is supposed to be between 30 and 60 ohms
Apr 16, 2009 | Whirlpool Dryers
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
See all Whirlpool LGB6000KQ Gas Dryer Questions
Dryers Logo
115 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
