Question about Acer NSK8458AN Keyboard
Can not get question mark to work - Acer NSK8458AN Keyboard
    Scholar:
  • 169 Answers
Well what you need to do is open the screws from the back of the keyboard and then you will see a rubber panel,clean it up using a cloth nad place it backin,it should work properly.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
1992 Lincoln Mark vii speedometer not accurate
Output shaft speed sensor problem.
Lincoln Mark VII Maintenance & Repair Questions - CarGurus
www.cargurus.com > Questions > Lincoln > Mark VII
CarGurusJohnny asked a 1988 Lincoln Mark VII LSC Maintenance & Repair question about a ...nicolse7 asked a 1992 Lincoln Mark VII Maintenance & Repair question ...
Sep 08, 2015 | 1992 Lincoln Mark VII
Setting timing marks to get vehicle to start after engine overhaul
Timing marks setting Corolla 4A-FE.
Align the notch on the crankshaft pulley with the "0" mark on the timing belt lower cover.
With the crankshaft pulley being aligned with the 0 mark on the timing belt cover, the hole on the camshaft sprocket should exactly be in front of the notch of camshaft bracket.
Hope that works.
May 04, 2015 | 1998 Toyota Corolla
My 2003 freelander crankshaft mark is set as well the cams but piston is not on top dead center on safe mark on sude mark piston is on top but cant turn it gets stuck
I've worked on freelanders loads of times presuming yours is the petrol model when you set the timing up on these when working on them. all pistons are at the halfway mark in the bores this is so no pistons strike the valves when taking the cylinder head off. So the actual mark if you want it set at tdc you need to take off the crankshaft pulley wheel it won't do any harm just four little bolts if I recall when this crankshaft wheel is out of the way you still have the gear there what the cambelt sits round. It is on that gear where the true mark is to set up the timing with no1 piston at tdc. Infact the pulley wheel needs to come off when changing a cambelt make sure the timing marks are set up properly check twice if nessessary then turn engine over one revolution by hand slowly to make sure no internal parts are hitting and timing marks come back together
Feb 07, 2015 | Cars & Trucks
Washer not working, dryer is
You should really provide a LOT more information than that. Such as what specifically is not "working".
If that panel is off, make sure it's unplugged. Be careful and good luck.
Dec 03, 2017 | Kenmore 24" Laundry Center w/ Electric...
Can some one show me timeing mark on 1997 nissan maxima please
wow a Nissan Camry.
what engine, ??????????
what are you doing, we dont know. so..
cam marks? chain marks?
spark timing?
in 1997, most cars have 6 or more marks.
Nissan V6? is it (guessing i am)
if doing major cam work , you will need far more that just mark data.
if doing serious work, i recommend the below
  1. a real FSM, from NISSAN if Nissan.
  2. alldata.com
warning:1
all nissan engines are All Interference
so doing cam work or finding engine dead,
do a leak down test by hand before cranking engine
or bend the valves.
after replacing chain, do a cyl. leak down test (a tool)
and if it fails, the valves were bent, do not crank engine
or the damage WILL cascade $$$$$$$$$$$$$$
Feb 22, 2014 | 2006 Toyota Camry
Cannon EOS 5d mark 3....it is in another language...how do you change it to English. I see the answer for mark 2 but this doesnt work on mark 3?
I was able to download the manual from Canon USA for free. I could search the page for you, but perhaps you also want the manual and read it yourself? here is the link to the download page:
EOS 5D Mark III
Oct 21, 2013 | Canon EOS 5D Mark II Digital Camera
F3LY-6328608-A does this part # work on a 1996 Mark VIII
If you are referring the spring for the fuel door it should work, although it is off a Mark VII and not a Mark VIII. From the information I found they are supposed to be the same length.
Jun 08, 2011 | 1996 Lincoln Mark VIII
How to find log on a calculator
Since I do not know what Kenko calculator you have I will remain general.
Locate a key marked log (for common decimal logarithm)
Try the two options. One of them is bound to work
  1. Enter a positive number and press the key marked LOG.
  2. If that does not work, press the LOG key and then enter a positive number. If the calculator displayed log( , with a left parenthesis, insert a right parenthesis before pressing the = key.
To calculate the natural logarithms (LN), look for a key marked with LN and proceed as for the common logarithm. I am sure that the syntax (key sequence) that works for the common log will work for th natural log.
If no key is marked on top of it with LOG or LN, it may be because those markings are ON the body of calculator. In that case the functions are accessed by pressing a key marked SHIFT or 2ND, or 2ndF before the function LOG or LN.
Jun 25, 2010 | Casio FX-260 Calculator
TIMING BELT MARKS DONT MATCH AFTER ENGINE TURNED OVER
dont worry about that you will have to turn the motor over 40 to 50 time before those timing belt marks line up again if your pulley marks line up correctly thats all you have to worry about
May 29, 2009 | 1994 Toyota Land Cruiser
My fuel sensor does not work it stays at the ful mark
The voltage regulator may be defective. Do all the guages work?
Oct 17, 2008 | 1992 Ford Ranger
Acer NSK8458AN Keyboard Logo
181 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
