Question about Dell Inspiron E1705 Notebook
Dell inspiron 1521 battery read low battery warning. plugged in with adapter booted up the screen went black and will not turn on. When pressing start button battery icon is amber.
  • mnguy7764 May 11, 2010
    Have you taken the battery out and tried to just start with the AC? Sometimes if your battery is bad, it will discharge so much it will not allow your laptop to run.
    Sergeant:
    Champion:
  • 253 Answers
Just remove and start with out battery by plugging in........
Posted on Jun 20, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My screen is black i havent had any problems new battery and adapter i shut it down woke up and its a black screen and cant see anything its never happened before i have no idea and ive had it for 4 years...
If you laptop appears to boot up and the hard disk LED flashes then the problem could be a back light problem. This could be a faulty inverter or a faulty CCFL lamp. Please click on this link to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jan 07, 2011 | Dell Inspiron 1521-JB Notebook
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
I have a Dell Inspiron 1521 and my screen is completely black. Yesterday it was flickering a little here and there. Now all I can see is a very fade image of the desktop but it is still black. I tried...
plz concert with hardware vender coz it is not possible for u. if u can see perfect boot screen than u must re installing ur oprating system.that mean ur hardware is perfectly working. enjoy good luck
Jul 28, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Dell inspiron 1521 laptop won't recognize a new 90 watt power
There are different types of Dell power adapters, some of them put out different amounts of power. While it is possible that the battery is faulty, it is more likely, given your error message that the adaptor is wrong. If you got it from Dell, you can call them and they will exchange it.
Cheers
Dave
Jun 21, 2009 | Dell Inspiron 1521 Notebook
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
I have a inspiron 1521 when I press the on button the on lites turn on but screen is off and cd drive will not open with the light on, the letter A next to the on button goes on and off then turn off...
There are all kinds of ways to test this but first is the harddrive spinning up and have you tried to connect and external monitor to see if the laptop is on or not .2 try to move the adapter cord and see if lites go on and off soo that you can check for loose power connections
3.Remove the battery and see if it will run on just the adapter
if it does at boot press the bios entrance botton you should see it at boot it will say F1 F2 ecs or Del one of these should allow you to enter bios to see if the harddrive is present
Mar 31, 2009 | Dell Inspiron 1521-JB Notebook
Inspiron 1521 won't boot up. Get read disk error.
hello!!
put ur OS cd and enter repair console and try fixboot command!!!
Mar 23, 2009 | Dell Inspiron 1521 Notebook
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Jan 24, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron E1705 Notebook Logo
200 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
